Bleeding the air with hose=had coolant coming from the threaded part of Inverter Bleeder Valve
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Jun 17, 2024.
  1. ski.dive
    ski.dive Active Member
    958
    241
    Hutchinson Island,FL. Mt. Snow,VT
    While Bleeding the air with a clear hose =
    I noticed coolant coming from the threaded bottom part of Inverter Bleeder Valve
    ***Is this normal, or is the coolant 'only supposed' to go out the top of the bleeder valve???
  2. fragglestickcar
    81
    43
    New York
    I suspect you're mistaking coolant falling from the valve top as coolant leaking from the valve bottom.
    You probably followed the consensus of a 1/4" inner diameter tube. Try a 3/16" and wrap that willy nice and tight.
  3. Mendel Leisk
    40,234
    Maybe when the bleed screw is loosened it’s loose enough for coolant to travel through the threads. I’d wager it’ll be water tight once snugged down again.
    Brian1954 and ski.dive like this.
  4. ChapmanF
    16,942
    Coolant will seep up around those threads. (It was worse on Gen 1, which had two bleeders, and one was on the suction side of the pump. The whole time you were trying to bleed, air would be sneaking in around the threads on that one.)
    I took the bleeders completely out and put a non-hardening sealant (I used the Hylomar blue stuff) on the threads, never another problem.
    Brian1954 likes this.
  5. ski.dive
    958
    241
    Will it also 'suck-air' back in the system from the leaking threads or is there NO suction there?
  6. Mendel Leisk
    40,234
    Apply a little grease around the juncture of screw and caliper hole?
  7. ChapmanF
    16,942
    These are inverter bleeders, not brake bleeders. So before I smeared the Hylomar blue stuff on my threads, I looked up its compatibility with coolant.
    If I ever wanted to smear it on brake bleeder threads, I'd look up its compatibility with brake fluid.
    All depends on whether the bleeder is located in a part of the coolant loop where the pressure is below atmospheric or above atmospheric.
    Gen 1 had two bleeders in the inverter loop, and one of them was in a below-atmospheric spot, so it would suck air in. The other one would seep coolant out.
    Gen 2 has only one bleeder, and it's in a spot where the coolant seeps out.
  8. Aegean
    Aegean Active Member
    451
    200
    Alexandria VA
    Obviously coolant will leak from loose threads but I doubt it will suck air. Even if it sucks air it will be negligible and not enough to make an air lock in the flow while eventually it will find its way to the reservoir.
  9. ChapmanF
    16,942
    A gen 2 inverter bleeder won't ever suck air, because gen 2 only has one bleeder and it's in the above-atmospheric section of the loop.
    If you ever meet a gen 1, there are two bleeders, and one is in the below-atmospheric section of the loop. If the pump is on it's about 10 inches H₂O below atmospheric there. If allowed to suck air there, it definitely will.
    How much air? "Enough to make an air lock in the flow?" isn't the main concern, to me anyway. As a practical matter, it's enough that if you're watching for the bubbles to stop coming out the other bleeder to know when you're done, you're never done.
    Aegean likes this.
