Bluetooth problems
Discussion in 'Gen 2 Prius Technical Discussion' started by shrink13, Mar 23, 2009.
  1. shrink13
    shrink13 New Member
    17
    I have a 2006 Prius with nav and I have connected several bluetooth devices in the past with no problems. I purchased a Blackberry Storm (Verizon) and although I can link up the bluetooth connection, as soon as I turn off or the car or the phone, I loose the bluetooth connection. When I check on the dash of the Prius, there is no indication that the Storm has been registered by the Prius. What am I doing wrong? Please help!! Thank you.
  2. ceric
    ceric New Member
    1,114
    Fremont, CA
    You should go to the Verizon dealer where you bought it from.
    There may be a firmware update for you. This sounds like a software/firmware issue to me (i.e. how the BT profiles wre implemented). Good luck.
    Maybe some Storm owners can shed some light on this.
  3. WWJD08
    WWJD08 New Member
    70
    Frederick, Colorado
    :mad: I have the 2008 prius, I have the motorola Razr from AT&T. one of the razrs gets recongnized and then when I push for phone 2 to be recognized I get connection failer. If I delete this phone than rergister it it works just fine unto I shut off the Prius . Then it reads connection failure. This such a Pain!:eek:.
  4. shrink13
    shrink13 New Member
    17
    Update. Thanks for the feedback. After countless hours on the phone and in person with Verizon, it was decided (only after trying another Storm), that it was indeed a BAD Storm and it was replaced. So, hang in there and don't give up when the Verizon folks tell you it is a problem with your car! Good luck.
  5. spitinuri
    spitinuri Member
    317
    On your phone under tools there is a bluetooth section. There are several options such as connect automatically or prompt etc.. I chose to connect automatically. Now whenever I get in my car and start it.... "BlueTooth". Btw I have a Blackberry Curve. I was having similar issues until I picked automatic connection.
    Best of Luck!
