brake look after rain (PICs)
Discussion in 'Gen 2 Prius Main Forum' started by ystasino, Dec 3, 2009.
  1. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    I assume this is not the brake rust people speak of because of the extreme non-use of brakes.
    What is this?
    07, 31,000 miles
  2. guru_del
    guru_del New Member
    33
    Lake Elsinore, Ca.
    surface rust, drive around a little and break and when you are done stopping a few times it should be gone. Nothing to worry about if it all comes off after a few stops.
  3. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    Yes, looks normal. Should wipe off with application of the brakes. Pearl looks like that after I wash her.
  4. Tideland Prius
    16,408
    rust spots. Perfectly normal since we don't use the brakes very often. I see it all the time (because it rains on the west coast) and after washing the car. Just a quick wipe by braking in N (which is easier than braking hard in D lol) will clean it right off.
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
  6. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Yastino,
    The flush hubcaps I made from the trim rings help with this a bunch.
  7. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Mentioned already, but it happens and it's nothing to be overly concerned about.
