Brake master cylinder
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Jay94501, Jun 11, 2022.
  1. Jay94501
    Jay94501 New Member
    Cali
    Today I went to check if my brake fluid is good or bad with the fluid pen but I notice after I dip the pen into the master cylinder I hit some sort of plate. The plate is exactly between the max and minimum level. My brake fluid was right in the middle of the level. The plastic piece in the middle is not like the 3rd Gen where you can remove it. So right now I scratching my head because usually you can just dip the pen in the fluid and check it.
  2. Jay94501
    Jay94501 New Member
    Cali
    I have a 4th Gen Prius
  3. Doug McC
    Doug McC Senior Member
    1,041
    391
    Midwest
    2022 Prius
    Is it possible you are hitting the removable plastic screen in the fill neck?
  4. Jay94501
    Jay94501 New Member
    Cali
    It's not like the circle plastic piece in the 3rd Gen. It's like a plate in the middle that I think you cannot remove out of the bottle neck.
  5. ChapmanF
    16,951
    Couple ideas:
    Could you fish any sort of skinny tube down in there, and use some kind of squeeze bulb to draw up enough fluid to test?
    Or would a test strip be easier to poke down there than the electrical gizmo?
    Or, crack open a bleeder at a wheel and take a small sample that way, test it, and add a bit of fresh fluid at the reservoir (if the test result is good and you decide not to replace it all).
  6. Jay94501
    Jay94501 New Member
    Cali
    I'm gonna take a picture inside of the Bottle neck probably today and upload it! Thanks for the reply
    Doug McC likes this.
