1. natural_tools
    natural_tools New Member
    32
    Dallas, TX
    When I push on the brake pedal, it makes a tone from, I think, the front right side. It's muffled, but it's not a scraping noise... it's like that sound a heart monitor makes when someone "flatlines" on tv.
    And it doesn't seem to be related to actual braking; I can just be sitting at a light and if I press down on the pedal a little harder, it makes the tone again. I can sit there and make the sound over and over by squeezing the pedal.
    Any guesses what this is? Something I should be worried about?
  2. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    is this a new sound you've never heard before? how long have you had your car?
    hmm, the car makes a lot of strange noises. there's that whining sound of the regen braking, the abs pump makes kind of a rapid ticking sound, lots going on with the brakes.
    if you haven't seen any dash indicator lights come on, you likely don't have to worry.
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i hear the ABS pump when i push harder on the brakes but it sounds like a ticking noise to me... but years of rock n roll music might explain that
  4. parrot_lady
    parrot_lady Member
    350
    Chicago Burbs
    check your door pockets... I had this problem when I got my car... my dad stuck two water bottles in the side door handles.... and well. yeah, that was the source of the noise.
  5. natural_tools
    32
    Dallas, TX
    I've had the car for about 20 months and have noticed the sound for a month or two. I know what you mean about the regen and pump noises, but this is definitely a different sound. The thing that's so weird is that I can be in Park and still make the noise when I push the pedal.
  6. Tideland Prius
    16,402
    I think I know what sound he's talking about. It's the one where the brake pump releases pressure. I think Dan can shed more light on this sound as I can't remember the full details.
  7. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    Has it been cold there in Dallas? My '04 makes a squeak when I go to cold weather. Freezing.
  8. natural_tools
    32
    Dallas, TX
    Nope, not that cold in Dallas (ever.) Technically, it started during warmer times.
  9. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    That would be more of a hissing sound.
    I have heard a faint squeal once when the car was off for a while. I think it might have been the AC system settling.
  10. MiamiPrius
    MiamiPrius New Member
    Miami, FL
    I have the same problem. Weird (honking) noise when the car isn't moving and the brake pedal is depressed...apparently I am pressing the pedal down too hard. I took the car in for service and they didn't find anything....but then again they didnt find the broken arm rest either...so I dont know how sharp these guys are. I don't fully buy it since I have had my prius for about 4 months and put about 10,000 miles on it and didn't have that problem until a couple of weeks ago. Did I suddenly start braking different? I don't think its the cold weather. 70 degrees may be chilly in Miami, but I don't think my Prius could be that sensitive. Anyone have an update on the problem or anyone get it fixed???
  11. MiamiPrius
    Miami, FL
  12. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    I have the same problem in my 05 prius at 5000 miles. Anyone can provide update on this fix??? pls..
