Brake Warning, ABS, and VSC lights on after mold mitigation treatment
Discussion in 'Gen 2 Prius Technical Discussion' started by Mountain_Prius, Apr 27, 2011.
  1. Mountain_Prius
    Mountain_Prius New Member
    Franktown, CO
    Brake Warning, ABS, and VSC lights on after Mold Mitigation treatment
    I have serious allergies and suspected to have mold in the ventilation system. A local dealer told me to try using a fogger on low with Concrobium mold control (a harmless all natural mold control solution) and fog the ventilation system. I popped off the glove compartment and cabin air filter and started fogging the system on a very low fog setting to reduce the amount of moisture. I had the vent system on high and fogged for about 15min cycling through upper, lower, and defroster settings to distribute the fogging throughout the system. Once I completed I wiped up any residual liquid around the cabin air filter assembly then noticed that the ABS, and VSC lights were on. I shut the vehicle off and then IG-ON again, lights were still on. Started to drive the vehicle and then the brake warning light illuminated as well.
    After reading a fare amount of posts on this issue, I doubt it is my inverter pump that failed. My guess is that a wire harness got a little wet near the ventilation system blower housing and that is why I have these lights on. Please let me know what options I might have to get these lights to turn off. Do I perform the “clear the skid control ECU DTC†procedure by Patrick Wong under the “179,975 Miles & Warning Lights Today?†post? Or does someone else have a better solution? Thank you in advance.
    -Mountain Prius
  2. Politburo
    Politburo Active Member
    971
    208
    Did you check the 12V? It's really the first place to start when it goes christmas tree on you.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    38
    Santa Fe, NM
    +1. If you had the car in IG-ON (not Ready) during the treatment, then you ran the battery voltage below the threshold where the ABS sensors operate.
    Put that battery on a charger at 4 amps or less for several hours. It is possible that you might be able to save it. The battery charging system is not like a conventional vehicle where an alternator is dumping 10s of amps into the battery while running. The battery charges at 3.5 amps while the Prius is in Ready, and you have a 36 amp-hour battery, meaning that the car should be in Ready for 10 hours to fully recharge a battery that was nearly dead. Most folks who run their battery down don't realize this, they just know that within a week of the first full discharge it is completely dead and has to be replaced. The battery is not designed to be deep-cycled. If you can get it charged to full quickly, the damage is somewhat mitigated, but it will never have the same capacity.
