Brake Warning Lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by askreeger, Jan 28, 2006.
  1. askreeger
    askreeger New Member
    Sacramento
    2005: Intermittant warning lights come on and remain on until the the car is restarted. Four lights are involved: the red brake light; the "take me to the dealer" light, the VSC light; and, the ABS light.
    When I first took the car to the dealer, the service writer thought the problem was a loose gas cap. Alas, that was not the problem. When I picked up the car, they said the codes they pulled were ambiguious and they were uncertain the problem was fixed. They could not get the lights to reappear.
    There were no lights for about a week but now most of the time I start the car, the warning lights reappear.
    Any ideas?
  2. richard schumacher
    7,664
    1,042
    United States
    Take it to a different dealer?
  3. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    This happened to my car once. It never happened again, so I ignored it.
    If it happens regularly now, seems like they should have a better chance to diagnose it now.
  4. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    bring it in somewhere else. the brake warning light is not set by a loose gas cap. have them put their diagnostic tech on it- there's usually one or more at each dealer that excels at and really enjoys diagnostic work. that's the kind of person who should be working on that problem.
    if they say they can't replicate it, ask the tech if he'd keep it as his daily driver for a day or 2. that's what my DH does if there's an intermittent problem that he can't replicate right away.
    what the heck are they doing giving you a car back if they're not sure it's fixed??? :rolleyes:
  5. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Sounds like an intermittent brake system problem to me. All of the lights refer to a component of brakes.
    Take Me Home (I like that) - generic for problem. Admittedly, not just for brakes, but brakes would probably trip it.
    Brakes - self explanitory.
    VSC - Vehicle Stability Control. Uses brakes to prevent you from fishtailing.
    ABS - modulates brakes to prevent wheel lockup when braking.
    Bad SKID ECU maybe? Or CAN communications to it.
  6. tochatihu
    tochatihu Senior Member
    9,457
    3,656
    Kunming Yunnan China
    2001 Prius
    I read of one NHW20 that gave an unhappy light because of an intermittent wheel speed sensor connector, but I don't know which lights in particular came on.
  7. Don-RI
    Don-RI Member
    153
    Cumberland, RI
    <div class='quotetop'>QUOTE(askreeger @ Jan 28 2006, 11:49 AM) [snapback]199337[/snapback]</div>
    Any updates on this? Just happened to me tonight -- 2004 BC9, about 41,000 miles.
    Dealer asked me if the car was "doing anything" as a result. To me, it seems as if the power is gone from the power brakes. I've loosened & tightened gas cap, and the brake lamps all light.
    Dealer will take a look at it tomorrow if he can fit me in. Fingers crossed.
  8. babsrocks
    babsrocks Junior Member
    45
    Pawcatuck, CT
    Same thing happened to me..... I took it to the dealer (Valenti Toyota in Westerly, RI) and they said it was a TSB (Something like a brake relay switch). And the lights haven't come on since.
  9. Don-RI
    Don-RI Member
    153
    Cumberland, RI
    Dealer did a diagnostics and got Code C1364 Info 243. They called CA tech assistance and were told to bleed the brake system. They did & the lights went out. :)
    An aside: the dealer had my Prius for three full days b/c they were "swamped" with work & had only one Prius tech working. Actual time spent on my car was only a couple of hours, of which I paid for only one given the insane wait for service. :(
