Breaking In
Discussion in 'Gen 3 Prius Technical Discussion' started by Morfeas, Feb 23, 2010.
  1. Morfeas
    Morfeas Junior Member
    greece
    Hello all…I’ve been reading the forum for months waiting my prius (for US it would be a V but with all packages, which for some reason is possible here) and so there is my question: What did you do for Breaking in the engine of your new car and for how long? I am kind of worried about how efficiently someone can run in a CVT.
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    The owners manual outlines the recommended break in procedure. From memory, for the first 1,000 miles (I believe), don't accelerate/decelerate too quickly, or drive too fast, and vary speed.
  3. PCK
    PCK New Member
    South Florida
    From the Manual
    For the first 200 miles (300 km):
    Avoid sudden stops.
    For the first 600 miles (1000 km):
    Do not drive at extremely high speeds.
    Avoid sudden acceleration.
    Do not drive at a constant speed for extended periods.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The Prius doesn't really have a CVT. The Prius has an HSD, which is essentially a variable electrical and fixed mechanical system that acts like a CVT. What this means is you don't have to worry about breaking-in the transmission.
    Vary your speed a bit, avoid drag racing and panic stops, and all should be good.
    Tom
  5. Morfeas
    greece
    Thanks for your answers guys
  6. justaguy
    justaguy New Member
    136
    california
    What if you just go 85 in the free way, is that considered going at high speed since the limit is 111 anyway:D
  7. lunabelgium
    lunabelgium Member
    269
    Belgium (Liège)
    qbee42 is right - don't be worried about that.
    Have fun with your Prius.
