Bringing an '07 out of storage after 3 months
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by justlurkin, Jan 9, 2011.
  1. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    Hi Priuschat,
    Thought I'd check with the experts here if there is anything I should watch out for, when I bring my Prius out of storage in the next few days. It's been sitting for 3 months, with the 12V battery disconnected, and the HV batt has been fully charged (by pressing the gas pedal and brakes simultaneously) before being put into storage. Before putting it into storage, I also had driven my Prius until it has only 1 pip on the gas gauge left.
    To bring it out of storage (assuming the 12V and HV batts are still working), is it as simple as driving it for a while to get the batteries charged up, or is there anything else I should do?
    My current plan is to drive it right away to the nearest gas station to fill it up to dilute the one pip of gasoline that's been sitting there for 3 months, then drive it around to charge up the batts. If there's anything else I should do, any enlightenment would be appreciated!
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    38
    Santa Fe, NM
    Check the terminal voltage of the 12V battery before connecting it. It should be 12.6V or more. If not, put it on a 2 amp charger overnight. There should not be any reason to do a significant amount of driving to recharge the HV batteries. They should be within one or two bars state of charge as when you parked it. Let us know if there is anything unusual. As long as you don't reverse polarity on your battery connection, everything should just work.
  3. Patrick Wong
    18,210
    6,510
    If you don't have a 12V battery charger, it is not necessary to actually drive the car around (unless you have errands to run.) Just leave the car READY overnight, and that will bring the 12V battery SOC back up.
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Check the oil level before starting the car.
  5. justlurkin
    499
    63
    Long Island, NY
    Thanks for all the tips guys. Brought my Prius out of storage today following all your advice-- Reconnected the 12V, and it fired up right away. There was still four blue bars on the HV battery (it was at 6 bars green when I put it into storage 2.5 months ago). Drove to the gas station to fill it up, and ran errands all day with it. Will leave it on READY overnight as per Patrick's recommendations to get the 12V fully charged.
    Thanks! I was half-expecting the worst but I'm glad my Prius has proven my fears to be unfounded!
  6. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    If there is a next time, keep the tank full and add fuel stabilizer. When storing gasoline, oxygen is your enemy so a near empty tank is the exact opposite thing you want to do.
  7. justlurkin
    499
    63
    Long Island, NY
    You raise an interesting point for discussion... The second-generation Prii like my '07 uses a flexible fuel bladder in the tank. I kind of figured the bladder would minimize air volume in there, which was why I drove it down to just 1 pip. Anyone care to comment if the gen-II is better off stored with a full bladder + fuel stabilizer or a drained one?
    Also I was hesitant to use a fuel stabilizer because I don't know if there would be any negative side effects. Can anyone tell me if this fear is unfounded?
    Thanks!
  8. Patrick Wong
    18,210
    6,510
    I agree with this practice.
