Bulb replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by astroqb, Jun 15, 2007.
  1. astroqb
    astroqb New Member
    :( Need help replacing bulb on Passenger door. Can remove the cover with the bulb but can't figure out how to remove the bulb without distroying the bulb holder.
    Thanks from a newbee B)
  2. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(astroqb @ Jun 15 2007, 07:03 PM) [snapback]462692[/snapback]</div>
    Shouldn't his be a warranty job? GM replaced a light bulb on my Intrigue under warranty. The only time it took one trip to the dealer to fix the problem.
  3. astroqb
    astroqb New Member
    <div class='quotetop'>QUOTE(JimN @ Jun 15 2007, 09:46 PM) [snapback]462764[/snapback]</div>
    I would like to replace the bulb with an LED if possible. B)
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(astroqb @ Jun 16 2007, 11:02 AM) [snapback]462996[/snapback]</div>
    Check with Darell at evnut.com He's big into the LEDs and probably has done that already.
  5. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Once you get the plastic holder loose from the door, disconnect the wires (it's a clip plug, press the lever and the plastic socket slips off the light assembly). The bulb is a wedge base bulb and just pulls out of the socket, sliding toward the end of the bulb and lifting out when free of the base. I got 1W side firing LEDs on eBay and I like the clear white light they put out.
  6. astroqb
    astroqb New Member
    <div class='quotetop'>QUOTE(efusco @ Jun 16 2007, 05:58 PM) [snapback]463128[/snapback]</div>
    :lol: Thanks Bill B)
  7. Bill Merchant
    4,096
    85
    <div class='quotetop'>QUOTE(astroqb @ Jun 19 2007, 07:08 AM) [snapback]464620[/snapback]</div>
    B) You're welcome! :lol:
