Buying prius w/ blown engine??
Discussion in 'Gen 2 Prius Main Forum' started by camil212, Aug 6, 2009.
  1. camil212
    camil212 New Member
    Central Jersey
    So far I have about $5k saved up and my goal is to get to $8k for a older 04up prius that I can care and love, so I came across this 05 w/o navi and the seller says there's a hole in the engine and needs a new engine. would this be worth going through all the trouble of getting it fix with a used engine and sourcing out the right person to do it? I can't afford car payments, so financing is not an option for me. He's asking $5800 which I think is too much considering I can get a high mileage one for about $8k but at least running. What's your take on it?
  2. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    IF you had experience with this, and wanted a DIY job, maybe OK. If you have to pay someone else, you will not come out ahead, and there are possibly other things wrong that you won't uncover until later. Don't take the risk.
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    what else does the car have.. in 04.. side impact, fogs, and rear wipers were optional. there were a few other things.... (no backup camera)... tape deck (i love my tape deck)...
    if i could pay only 8k for my prius (i have nav though).. i would have saved THOUSANDS.. because i financed. at least you're not going to finance. if 8k is all you want to spend in the end... you probably won't hit that target. at least you'll know it has a new engine in it though!
    what's the mileage? how long has it been sitting? has the hybrid battery been removed or tampered with?
  4. richard schumacher
    7,664
    1,042
    United States
    No. That $5k car will turn into a $10k car before it ever goes a mile. (A "hole in the engine"? How did *that* happen? and just imagine what else could be wrong with it.) Continue your original plan, which is a good one: save up until you can buy something that actually runs.
  5. camil212
    camil212 New Member
    Central Jersey
    yeah the guy's emails are really dull and doesn't answer the questions exactly. I asked him about specific options on the car, like smartkey and camera, all he says is car is loaded and leather, what the heck does that mean?, so I decided to stick to my original plan.
  6. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Camil,
    Its rare for Prius cars to have the engine go. Its more likely to have a motor short as an untimely cause of somebody selling it short of its usual life. That is not a terrible job, but its allot of work to replace the transmission with a used one. Both the drive motor/generators are in the transmission.
    Battery failure is not going to result in junking a car, as they are relatively cheap, and very easy to replace.
    There was one guy who did is own tranny replacement and its documented on Prius chat here.
    If your capable with body work, then getting a salvage car might be the route for you. The insurance companies have been salvaging readily repairable vehicles, simply because they cannot be sure to have the car repaired in a timely fashion, in my opinion. Minor corner damage which is repairable, but takes Hybrid Car knowledge cars are out there. One guy on here, also meticulously detailed, went that route.
  7. Patrick Wong
    18,200
    6,491
    BTW, leather was not a factory option in 2004. So if the car has leather, this would have been an aftermarket addition.
    I agree with your decision to avoid this particular vehicle. Since Prius engine failure is unheard of unless owner abuse is a factor (i.e., failure to change engine oil/filter timely), who knows what other problems the car has.
  8. spitinuri
    spitinuri Member
    317
    Patrick speaks wisely. Buy used and cared for. Somebody must have abused that car to blow the engine.
  9. tochatihu
    tochatihu Senior Member
    9,508
    3,670
    Kunming Yunnan China
    2001 Prius
    I am not suggesting purchase this vehicle.
    A hole in the oil pan from road debris could kill a Prius (or most any other) engine in about a minute. In such a case, the only owner abuse would have been missing the (dim) oil warning light. Could happen.
  10. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    MY 04 IS MINt AND will take payment:) 9K
  11. V8Cobrakid
    3,790
    152
    ...the 04/05's don't have an oil light.. for that matter.. i'm not sure if any other models do either.
    9k.. good deal for an 04.. that's only a few hundred dollars over what i owe on my 04.
