c1391 with no other codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Alex Marks, Feb 21, 2024.
  1. Alex Marks
    Alex Marks New Member
    New Orleans
    Newbie here. I have read many posts on this code and have a few questions.
    I have a 2009 and I surmised that this was the code from the ((!)) ECB blinking out code 69. The ABS and VSC lights were blinking the "look at the ECB light" codes.
    When searching this code most people are reporting multiple codes or at least these two c1256 & c1391 together. Is it in anyway notable that this is the only code I have? People mention the brake master cylinder but most of the dialogue concerning this code points to the feared brake actuator.
    I have cleared the lights and seen them return and in general the main thing I am experiencing is that the brakes momentarily disappear at start up and then kind of return to functioning. If I'm in a hurry and put the car in drive it can be scary as the brakes are not there but will engage after an anxious second or two or three! Once driving I have not experienced any issues with the braking system. Most notably the parking brake does not engage when pressed down. Just comes right back up. Is the actuator the main thing I'm looking at based on this description? This does not happen at every start up at all, could it be sub 50 degree cold mornings?
    Also...I was having battery issues and needed to jump the car multiple times. It seemed like the battery was bad so I decided to buy a new battery since I had also read that voltage issues could cause brake system lights to come on.
    Anybody know a mechanic in New Orleans my guy won't touch the Prius :cautious:
  2. Alex Marks
    New Orleans
    Does the whirring/clicking brake actuator noise happening frequently play a roll in this diagnosis? Or is that normal Prius behavior...I'm starting to feel like the writing is on the wall :cry:
  3. Tombukt2
    Tombukt2 Senior Member
    11,692
    2,072
    Durham NC
    I'm not understanding why you're parking brake is acting up that should have nothing to do with anything to do with the braking system wants the parking brake is removed It not setting is a problem The little piece of plastic or whatever holes it down so you can push it again to bring it back up is not clicking or sticking like it's supposed to that should have no effect on the rest of your brakes I wouldn't think It is a mechanical parking brake so I would probably rule that out I haven't used my parking brake except to push it down to bleed after installing a new actuator assembly usually on the generation to the brake foo bar mess is to do with your actuator generally It is possible some other part could be going haywire like if there's a computer that runs the brakes the body control module something along those lines haven't looked in the manual enough to know usually you're just replacing the actuator here it looks like you may have a little more troubleshooting to do I've never had any of the amber lights flashing including the exclamation point ABS and or VSC they don't flash mine just come on and stay forever until the actuators changed and the linear valve offset can be calibrated and all of that till that happens those white stay on so far in the two models that I have here and dealt with this problem.
  4. ChapmanF
    17,013
    Yes. Because of the way the parts are split up in gen 2, the actuator assembly is pretty much one-stop shopping for this issue. It isn't like gen 3 where the pump/accumulator and actuator are different assemblies and you have to figure out which to replace. In gen 2 it's easy.
    Your parking brake issue is unrelated. That's purely a mechanical pedal, cable, and ratchet. The ratchet is supposed to grab the first time you press the pedal, and release when you press it again. In very cold weather, the grease on it is slow to move, and the ratchet won't grab instantly. Pressing the pedal down and holding it for a moment usually works for me, gives the cold-greasy-ratchet time to ease into place. Depending on where you are and how cold it gets, you might have to hold it longer than I do.
  5. Alex Marks
    New Orleans
    Thank you for the reply. I paid close attention just now to the vibrating pump sound of the actuator and while driving it basically runs constantly just pausing for 2-3 secs at a time. Should I move on to getting quotes for replacing the thing or should I have Toyota do the $175 diagnostic? I guess the only question is whether a leak could be the culprit outside of the actual unit itself?
  6. ChapmanF
    17,013
    Quite unlikely to be anything outside that unit itself. Clearly you have an internal leak: an external leak that big would have emptied your fluid reservoir and made a lake on the ground by now.
    There aren't a lot of places outside the actuator where an internal leak could be, as a lot of the lines coming from it are dead ends.
