C1445 driving without initializing steering angle sensor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Frank Quigg, Dec 13, 2024.
  1. Frank Quigg
    Frank Quigg Junior Member
    V4R0B6
    Can not find the initializing procedure in Techstream. Can clear the code but after driving 2-3 kilometers it returns. Appreciate any help.
  2. ChapmanF
    16,949
    As far as I know, there is no manual calibration procedure for a steering angle sensor. If you view its reading on a scan tool when the car's just been turned on, it shows some bogus reading like -1300°. The reading updates to realistic as soon as you've driven straight for a bit, which the ECU can tell by the zero yaw sensor reading and the wheel speeds being equal. (So, this relies in part on the yaw sensor and there is a manual calibration for that, but probably of little interest unless someone has disturbed the yaw sensor.)
    While I don't have easy access to the repair manual right now, this looks like probably the right C1445 details here.
    The language there about "calibration cannot be obtained" does not suggest to me that there's any manual calibration step you've forgotten to do, and more that the car's normal automatic calibration hasn't worked out for some reason, such as the angle sensor not working right, or reporting a value that is off by more than the auto calibration process expects.
    If there's been a recent change to the alignment or steering wheel centering, that repair manual excerpt does seem to suggest that relearning the yaw sensor zero point might help. There is a "when not using the Techstream" procedure for that, which involves jumpering a terminal ("TS", not the "TC" terminal that gets mentioned more often) to ground.
  3. Frank Quigg
    V4R0B6
    Thank you for responding. Much appreciated.
    This started with the code C1231. Problem with the steering angle sensor. I replaced the sensor. Techstream showed the new sensor working perfectly. I followed the Techstream procedures for "Calibration" and "Initialization" and all the lights went out so I thought all was good until I drove it. I will go back and do the procedures again. I must have missed a step. Also won't hurt to try the "paperclip"
    Thanks again,Frank
