Cabin air filter is it free in the 25K checkup?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by FishHawk, May 23, 2011.
  1. FishHawk
    FishHawk New Member
    176
    I wonder if Toyota will change the cabin air filter for free in their 25K free maintenance checkup? I know that the oil should be changed at 10K but wonder if the filter can be effective for the 10K mileage.
    I'm used to changing my oil and filter at 5K. FishHawk
  2. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I don't know about the cabin airfilter but I was shocked that I got a new engine intake air filter free at my 20k mi. oil change.
  3. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    I don't plan on replacing my cabin filter, unless it's so clogged that air won't pass through it. The owner's manual says to use compressed air to clean the cabin filter. So far, this has worked nicely for me, but I'm only at 25K. My filter still looks brand new.
  4. twittel
    1,605
    148
    Mt. Pleasant, SC
    I forgot one thing. Your oil filter definitely needs replacing every 10K miles. I think maybe this was the concern of your post.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    I have changed my own cabin air filter but I have seen others on here say that the dealer will change the cabin air filter "for an additional fee".
    If your dealer tells you this, you can change this yourself very easily. Search on here and there are some good instructions on here with pictures of how to change the filter. The filter at an auto store or WalMart is between $10 and $15.
  6. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Changing the cabin air filter was such a PITA for me I'm not sure I'm ever changing it again.
  7. remco
    remco Junior Member
    Warwick, Rhode Island
    I was surprised that the dealer changed my cabin filter at no charge when I brought my 2010 for its 2nd free oil change @ 15K miles. I just brought it in @ 20K miles for one of the free tire rotations and they said the filter looked like it should be changed soon. He seemed befuddled when I said they just changed it 5K ago. He mentioned I must be riding on dusty roads (not). I know they changed it because I had to go back to the dealer as the glove compartment damper was not connected. You hit the button and the door dropped like a guilletine without the damper.
    They asked when I pulled in if the wipers were OK . Not expecting them to cover the replacement cost, I said they were fair but not in desperate need of replacement if I was paying....again the replacced the at no charge...but not the rear. I thought mine were fine till I used the new ones. So far I'm pleased with the service from the dealer under the free package. I may even take it back for the oil changes when it runs out. Let the bottom oil cover flap fall off on their lift.
  8. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    I replaced the filter with one from a local auto place and it did not filter the cabin. You can not clean them with compressed air. It is the carbon that filters the air.
    I love working on cars. Replacing the filter is a 5 min job for me.
  9. motorking
    motorking New Member
    detroit
    2001 Prius
    Hello to all,
    i am the tech manager at fram filters. We have a cabin Af for the your cars that has both carbon and arm and hammer baking soda in it for odor absorbtion. We also have installation instructions in the box and a web link to a installation video as well.
  10. SWprius08
    SWprius08 SoCalprius
    170
    Los Angeles (SFV)
    I never got free cabin filter even with the 30,000 major service, I just got the 45K service done. Its ridiculous for the dealer to be charging $ 69.99 for it. WHAT!!! .. the filter is $ 21 only, $ 49 labor?? for what??. Changing the cabin filter is very easy, can be done in 5 minutes. There are many videos on how to change it.
  11. SWprius08
    170
    Los Angeles (SFV)
    How much are they for?
  12. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Really ? It is a 5 minute job. Why was yours such a PITA?
    Open glove box, drop linkage on right side, press on sides of glove box so stops clear the sides and the glove box comes out. Remove the cabin air filter cover and slide out the filter. Either clean or replace filter, re-install glove box, attach side linkage and close glove box.
  13. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Agreed. One of the easiest DIY maintenance items I've done.
  14. Mendel Leisk
    40,231
    I was a little suprised to see Toyota documentation with instruction to blow compressed air through filters in reverse. Mainly because Honda always cautions not to do that.
    Could be just to sell more filters, but I think part of the rational, in particular with the engine air filter, is that you are cleaning the loose large particles, but not the stuff that's more deeply embedded. Also, blowing the filter out may migrate loose stuff around to the clean side.
  15. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    had great link for cheap cabin/engine filters from place in Chicago that i could get by mail order. gave great discounts when buying lots of 3. any one have it? i cant find it.
    i live in WA and pollen around here really clogs them up. so i try to change them out in June which is basically between the two major seasons we have here (trees verses weeds/grasses)
    i had an extra set from my 2006 that i just sold, but they do not quite fit
  16. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    thats only for the cabin air filter. Nobody says to do that with engine air filter.
  17. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Agreed - a simple change that takes less than 5 minutes!
  18. itssunnyv
    itssunnyv New Member
    33
    Studio City, CA
    My dealer just said they would change both filters for about $140. I always changed my own air filters when I had a non-hybrid. I'm sure it's not much harder, yes?
  19. DavidA
    2,339
    1,817
    Chicago western burbs
    "Free" is not a word my dealership knows, except for a free "Hello," a "Thank you," and "We washed your car for free."
    The engine air filter requires a 10mm wrench (or large phillips screw driver) to loosen the intake hose clamps to the left of it, unhook two clips on the front of the filter housing and a total of about 4 minutes of your time to remove and replace it. Could be 6 minutes if its your first time. Mine has been pristine clean for the first 16,000 miles, so I haven't swapped it for a new one yet. Same with the cabin air filter, and that also takes the same time to do it yourself. Detailed directions for changing the cabin air filter are in your owner's manual, and with diagrams. Be careful when you try to pry the glove compartment outward not to bugger out the clips. That plastic is somewhat easily broken.
  20. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    If you can't change a cabin filter and an engine air filter ... you shouldn't be driving a car and you should have to give up your man card. Geesh ....
    REV
