Cabin Noise & Radio/CD volume
Discussion in 'Gen 2 Prius Main Forum' started by BigFire, Apr 1, 2005.
  1. BigFire
    BigFire New Member
    Los Angeles
    In my 4 weeks of driving (3 tanks of gas), I've notice a somewhat disconcerting trend. Nominally, for FM & CD, I set the volume at 20 for freeway drive (the ambient noise from the road demands). For AM radio, that might go to 25. However, when driving the non-freeway, the volume would feel way too loud, and I have to crank down to 15.
    Does everyone does this?
  2. jeromep
    jeromep Member
    827
    Eastern Washington State
    Your ears must be much better than mine, which I'm pretty sure of that because of what I know about my ears right now, but I run my stereo at about 25 in town and 30 on the highway. Due to differences in recording line levels for CDs volume can vary greatly between 2 different CDs. The same can be said about radio, the strength of signal, along with the gain levels the broadcaster is using will cause there to be a significant difference in volume levels you will want to use between stations and even bands.
  3. timmsumm
    timmsumm New Member
    Seattle, WA
    Depending on what tunes are flowing out of the iPod I usually run between 45 and 55 - that way I don't have to worry about road noise :D
  4. jeromep
    jeromep Member
    827
    45-55? Wow that is pretty darn loud. My ears are a mess, however that is terribly loud.
  5. Tideland Prius
    16,402
    I leave it at 20, sometimes as low as 15. This is city driving
  6. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    I find the Prius quite noisy on the freeway due to tire noise, so yes, I do play the stereo louder on the freeway.
    I can cut down the tire noise noticeably by running at mfg. recommended tire pressures, but I have to compete with the other Prius drivers at work for mileage bragging rights, so I run a few pounds higher for the extra one mpg or two mpg.
