Can I run 19 inch trd rims on my 2012 Prius 3?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Artm635, Aug 19, 2012.
  1. Artm635
    Artm635 New Member
    I just bought a Prius, and want to make it look good, so I got on craigslist and picked up a set of 19 inch trd rims off of a 2010 xb, the diameter looks the same, and they seem pretty light I mean, they are trd's, just wondering if its ok, and how bad it will hurt my mpg
  2. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    The 2010 XB has a 5 x 114.3 bolt pattern and your 2012 Prius has a 5 x 100 bolt pattern. The TRD wheels won't fit your car unless you install wheel adaptors.
    You may also have clearance issues (wheel may stick out too far) as well.
  3. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Like Dakine stated above and you will lose 4+mpg depending on tire choice. My personal guess is a 6mpg loss with a 19" wheel.
    If they do fit after you get the adapters, you will need to lower it or it's going to look like a donk IMO. :)
  4. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    F8L said gonna look like a donk!
    Posted from my iPhone via the Tapatalk app.
    F8L likes this.
