Can I slightly open windows w/o starting engine?
Discussion in 'Prius c Main Forum' started by davide, Apr 7, 2012.
  1. davide
    davide Junior Member
    86
    suburban Detroit
    I haven't bought my "c-two" yet, but when I do, I'd like the ability to (in the morning) get in and just crack open the windows slightly (to reduce the interior heat build-up as it sits in the sun before I leave for work hours later). Can I do this without starting the gasoline engine? If so, what is the procedure?
  2. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
  3. davide
    86
    suburban Detroit
    I haven't bought my "c-Two" yet, but when I do, I'd like the ability to (in the morning) get in and open the windows just a bit (to reduce the interior heat build-up as it sits in the sun before I leave for work hours later). Can I do that without starting the gasoline engine? If so, what is the procedure?
  4. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    turn key to ON, but not enough to start the car...
  5. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    OP, I merged two of your threads into this one, please don't ask the same question in two separate threads. Thanks.
  6. SquallLHeart
    826
    247
    San Jose, CA
    thanks!! but yeah.. it's like any other car.. you can turn on the car without starting the engine..
  7. davide
    86
    suburban Detroit
    Sorry, I didn't intend to. What happened was: I mistakenly posted my question in the Prius v forum, then realized my mistake, so I retyped it in the Prius c forum. How it appeared there twice, I don't know.
  8. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Not a problem davide, just next time report the post while still in the v forum and one of us will just move it to the right forum.
    As for your question as others have said, its like using a key in a regular car and turning the key one or two clicks to put it into accessory without starting it to use the windows/radio etc. Instead of a key you just push the button twice for accessory and again to turn off without pressing on the brake.
  9. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    A C 2 really DOES have a key, you don't go keyless until C 3.
    http://www.toyota.com/priusc/trims-prices.html
  10. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    I know Jimbo, what I forgot was I was in the c forum.
