Can you put 15" tires on all 4 wheels?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hipoptics, Jul 10, 2011.
  1. hipoptics
    hipoptics New Member
    Can you put 15" tires on all 4 tires or should you keep the rear two tires at 17"?
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Come again? :confused:
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    If you have 15" on the front and 17" in the rear someone has screwed up your car big time.
    If you have a touring model, then you get 17" on all 4 tires. Anything else you have 15" tires. Also make sure you get LRR tires on all 4 no matter what you switch to, or expect a significant drop in MPG.
  4. hipoptics
    Paradox- misread the specs. I believe either 15" or 17" tires can be used on all four tires and not a combination of the 2.
  5. hipoptics
    Thanks Toaster... my mistake
  6. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Did your car come with 2 different size wheels on it?
  7. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Bliddy-bah, bliddy-bah, duh-bah-bah-bah.:crazy:
    Next time try using tricycle tires.
  8. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    don't mix tire sizes. with the way the suspension is set up, the car starts to oversteer and gets a little hard to control at high speed .
    also.. if you change tire sizes too much, the computer trips out because everything needs to rotate at the same pace for traction and skid control to work.
  9. ursle
    ursle Gas miser
    1,049
    192
    NH
    Is this a subtle blonde joke, or are you a blonde;)
    A blonde cop stops blonde motorist and asks for her driving license.
    The Motorist scuffles around in her purse and can't find it. She says to the cop, "I must have left it at home officer."
    The cop says, "Well, do you have any kind of identification?" The motorist scuffles around in her purse again, and finds a pocket mirror.
    She looks at it and says to the cop, "All I have is this picture of myself." The cop says, "Let me see it, then." So the blonde motorist gives the mirror to the blonde cop, who looks at it, and replies, "Well, if I had known you were a police officer, I wouldn't have even pulled you over. You can go now."
