Can't use EV mode
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bobdrad, Mar 25, 2011.
  1. bobdrad
    bobdrad New Member
    Central Florida
    Since I purchased my 2010 I've never been able to use EV mode. I know it's just a novelty, and actually hurts gas mileage (due to the need to convert gas to electricity to recharge the battery), so I haven't lost sleep over this, but it is somewhat annoying.
    Is there a known problem with 2010s and EV mode? No matter how gently I apply the accelerator it pops out into ECO mode again almost immediately with a message like "insufficient charge" (or something like that), even if the battery is near full charge (I've never seen it fully charged).
  2. krelborne
    krelborne New Member
    295
    Alabama
    Insufficient charge? Mine usually complains about excessive speed, usually around the 10 mph mark. I've only found it useful for moving between parking spots or shuffling it around in the driveway.
  3. bnaccs
    bnaccs bnaccs
    191
    Colorado
    My 2010 just cancels out ev mode if I push the gas too hard, or go above 25 mph where it then say" deactivated due to excessive speed." Also after driving around for a full mile ev MODE. After driving around in my neighborhood for a full mile it was deactivates due to a low battery charge. I never have seen the full battery charge message as a reason to deactivate. You just need to practice using it in parking lots or other areas where their are not many cars and you can maintain a speed of 10-20 mph.
  4. caferide
    caferide New Member
    Evanston, IL
    I have not been able to use EV mode either. No matter how gradually or gently I accelerate -- EV mode deactivates due to "excessive speed". I took my Prius to the dealer today to have it looked at and was told that it was "normal". I'm not satisfied.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    There are numerous threads on here addressing EV mode and what parameters need to be satisfied before EV mode is available. Use the search function and read some of these threads. This will help you understand when you can and cannot use EV and why.
  6. tomstodola
    tomstodola Member
    129
    Ontario, California
    2019 Prius Prime
    you cannot go to EV mode while the car is moving. mine works pretty well if I baby the pedal. I can get it to 25mph in some cases. I would never use this when other cars are around me - it is inconsiderate to other vehicles because othe severly reduced rate of speed necessary to keep it in EV mode.
  7. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    25 mph limit when warm
    10 mph limit below a certain point in warm-up
    unavailable when cold
    unavailable when SoC too low
    unavailable when other conditions not met
    see my post #10 here
    http://priuschat.com/forums/gen-iii...-discussion/76501-gen3-warming-up-stages.html
    from which I pulled this:
    *Notes on EV Mode
    Recommended uses:
    Moving around the driveway or parking area
    Drawing power in expectation of major regenerative opportunity (e.g., about to crest a mountain)
    EV mode conditions:
    Engine coolant at or above 0C/32F (20C/68F on US models?)
    Windshield defogger not in use
    Hybrid system (HV battery) in the range 0C/32F to 46C/115F (no x-gauge yet?)
    HV battery state of charge (SoC) at or above 4 bars
    Speed below the applicable limit (10 or 25 mph)
    Not in S1a or S1b
    EV mode terminating conditions
    Failure to meet initial conditions (do limits differ?)
    Excessive power demand
    EV maximum speed by stage:
    S0 and S2: 10 mph
    S3 and S4: 25 mph (10 mph if engine coolant below 70C/158F)
  8. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    That's easy, with a ScanGauge.
    When the engine RPM is zero, the coolant temp is at least 155°F, and the speed is under 25, you can engage EV mode. You can even push acceleration into the PWR (red zone).
    Compared to what the PHV offers, the cordless EV is quite limited. But it does give you a taste of what's to come. And is still very handy in heavy stop & slow traffic.
