car is throwing P0800 and P3011 codes and the elec.motor disconnects from battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lexia Blake, Jan 14, 2024.
  1. Lexia Blake
    Lexia Blake New Member
    Massachusetts
    I have a 2007 Prius that only has 64,000ish miles that 12v battery has been replaced twice both with refurbished batteries. This latest battery was replaced prior to me traveling abroad for 4 months in which the car was not driven but started occasionally.
    Since I have been home the red triangle of death has been up and when scanned codes P0800 and P3011 came up.
    The main issue is when driven in the high way the car temporally smoked which could have been related to spilled oil in the hood but also was relying mainly on the gas motor.
    Overall not sure what to do as I need to drive to work but the car is in terrible condition.
  2. Tombukt2
    Tombukt2 Senior Member
    13,743
    2,486
    Durham NC
    Looks to me like you need to undo the coils plugs and have a look The 300 whatever code you have is talking about cylinder one misfire I believe maybe that plug or all the plugs are just old and near dead that would be a good place to start misfiring is no good and generally in this engine it's not a head gasket or the fire being put out by water it's usually a bad plug failing coil or the plug well is filled with oil from bad valve cover gasket and o rings
  3. ChapmanF
    18,873
    I don't think P0800 is a code you're getting: that's an SAE standard trouble code for a transfer case, and your car isn't four-wheel-drive and doesn't have one of those.
    Once you confirm the code you've actually got (P0A80, maybe?), you can use the Report button to have it changed in your thread title too, which will help other people find the thread.
    Tombukt2 and Brian1954 like this.
    52,671
    what code reader are you using?
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,010
    NJ-USA
    IF the HV battery was recently replaced AND you have codes (P0A80? & P3011), then I would look into getting the battery replaced again under warranty.
    It's not uncommon to have problems with "refurbished" batteries. At best you might get 2-3 years. Sometimes you get a few months (or even weeks). It all depends on what the "refurbisher" did to the used battery modules before it was sold to you.
    The most reliable solution is to get a new battery pack from Toyota.
    Brian1954 likes this.
  6. Lexia Blake
    Massachusetts
    ODB2
  7. bisco
    52,671
    unfortunately, most won't read complete prius codes because of all the computers.
  8. Tombukt2
    13,743
    2,486
    Durham NC
    Your HV battery is well over the 10 year limit . Or that's generally the max limit you'll get out of a HV battery in these vehicles some have gone longer but it's certainly not the norm many have been replaced much earlier so there's always these things If that's an original battery it'll have frosted nuts and discolored bus bars and so on and so forth if somebody looks.
