car shakes ????
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jimmy9299, May 29, 2009.
  1. jimmy9299
    jimmy9299 Junior Member
    2008 everytime i take off from a stop postion the car shakes from the front of car and then goes away when i get over 10mph ??????
  2. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    you need a alignment or a balance:)
  3. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    I'm not certain about that, Sandy. Usually alignment or balance issues get worse with speed, not better. And often at low speeds they are undetectable.
    Jimmy, your car should still be under warranty. I would definitely take it in for a checkup to a Toyota shop.
    Could you provide additional information? Such as:
    • does it happen all the time, or only when the ICE is running?
    • does it only happen when accelerating? or will it still happen if you are just maintaining a speed of less than 10 mph?
    • are there any type of warning lights that come on when it happens?
    • does it only happen when the car is cold, warm, or all the time.
    Best wishes,
  4. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    That's wierd for the reasons Frank mentioned above.
    Any chance the brakes are grabbing just a little? I'm thinking this would be noticeable at lower speeds and smooth out as speed increased.
