Car Won't Start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rayrico55, Jul 10, 2010.
  1. rayrico55
    rayrico55 Junior Member
    I have a 2007 Prius, the ready light would come on, but when I pushed the start button, the engine would turn over and stop? Had the car towed to the Toyota Dealer, and they told me that the HV ECU was bad? After replacing the ECU, it still would not start, now the dealer is telling me it's the inverter or the transaxle? Can anybody help?
  2. Patrick Wong
    18,200
    6,490
    Please post the DTC (diagnostic trouble codes) that your car has logged. Ask your service writer for this info if you don't have it yet. It's hard to say much about your situation without knowing this.
    Also, what is your odometer reading? If under 60K miles then the HV ECU, inverter and transaxle are all still under warranty so no worries. From 60K -100K miles the HV ECU and inverter will be covered.
  3. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    If the READY light is on, the car is on. If you then push the START button, you are turning the car off.
    Just thought I'd mention that for innocent bystanders.
    2 people like this.
  4. rayrico55
    The diagnositics code was POA1D, the car has over 100,000 miles so no warranty?
  5. Patrick Wong
    18,200
    6,490
    DTC P0A1D does point to the hybrid vehicle ECU having a problem. Since that part has been replaced, does the same DTC reappear or has a new DTC come up?
    If P0A1D persists, what is the three-digit info code that accompanies this DTC?
    If no other DTC appears, I am wondering whether your car might have a wiring harness problem. Was the car in a significant accident prior to this problem appearing?
    I agree that your car is no longer covered under warranty. What repair action does your dealer want to take now, and are you willing to authorize that expense?
  6. rayrico55
    Thanks Patrick for your reply! The code is the same, I rebuided the car 3 years age and it has ran great until now. The dealer is wanting to change the dash wire hardness, inverter or transaxle? If I have to change the wiring hardness, which one do I replace? dash hardness or the engine wiring hardness?
  7. Patrick Wong
    18,200
    6,490
    OK, I assume that the car was in a severe accident three years ago, and that you know the location of the damage. You'd have to look at the wiring harness that would have been stressed or damaged by the accident, and examine the wires and the connectors very carefully.
  8. rayrico55
    After viewing the wiring hardness, I plan on replacing it! Used engine wiring hardness are about $300 to $400! Dealer are asking $2,389.00? Any tips on placing the harness?
  9. Patrick Wong
    18,200
    6,490
    No, except that job is going to be a big pain in the a__. Good luck.
  10. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    P0A1D has 57 different information codes associated with it. Of those 23 are given as 'Impossible to drive' in the fail-safe chart. For nearly all of them, the solution given is to replace the HV ECU. There are a few where the service manual says to check and resolve any other DTCs first.
    INF code 142 is a self-check on the 'start' (ST2) pin's connection. It's supposed to be about 5V coming from the Power Source Control ECU (monitors the power button) to the HV ECU. If it's more than this the HV ECU assumes it's shorted to the 12V bus and sets the code. The fail-safe action is to fail to start. Check the wiring harness between the ECUs. If that seems to be OK replace the Power Source Control ECU.
    The HV ECU does have two separate ground connections, although they do ultimately connect to the same chassis ground point. I don't know if it would behave strangely if one (or both) had a poor connection, thereby causing a voltage to be seen between them, but I think it's a possibility worth checking for.
  11. rayrico55
    Mike, thanks for the reply, you said check the wiring harness between the ECUs, wiring hardness from the HV ECU to where? to the start button?
  12. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    Check that the 5 volts supply is 5 volts. I had mine fail. I made my own 5 volts supply, rather then replacing the ECU. Car works fine now.
  13. rayrico55
    I placed the HV ECU? So, why sure I replace the 5 volts supply? And if I need too can you tell me how?
  14. Mike Dimmick
    963
    249
    Reading, UK
    The HV ECU to the Power Source Control ECU. The PSC ECU appears to be behind the steering wheel, behind the panel that the START button is mounted on. The HV ECU is behind the glovebox.
    It looks like this is the main Instrument Panel Wire harness. There's a joining connector between two parts of the harness behind the combination meter (i.e. dashboard display). The Wiring Diagrams part of the manual seems to say that the connector joins the Instrument Panel Wire with itself, which seems unlikely.
    If it's a $2,000 harness - and I can believe it is, since it has something like a hundred wires in and many custom connectors hanging off it - it's worth checking continuity and stability of the various wires and connectors, and repairing only those wires and connectors that are damaged. As Patrick says, it'll be a pig to replace as it runs right across the width of the dash, and connects all the major ECUs together.
