center arm rest
Discussion in 'Prius c Main Forum' started by pippijones, Mar 14, 2012.
  1. pippijones
    pippijones Junior Member
    63
    Philadelphia, PA
    Anyone that owns or has test driven one of the C's, is the center arm rest adjustable? I test drove a C last night (second test, way better then the first test) and I tried to adjust it because where my seat position was the arm rest was useless. And if it is adjustable.....how did you adjust it?
  2. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    yes, it is slightly adjustable. the top portion slides forward a few inches. it took me a couple of tugs but then, voila! now i keep it forward all the time. its a little more awkward to open but its ok. now if they would just fix those loser cup holders!
  3. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    yeah.. I was wondering the same thing before too.. but it does slide forward a bit.
  4. Kirkuleez
    Kirkuleez New Member
    220
    24
    Oshkosh, Wisconsin
    Really, because I was giving mine some pretty good tugs after the owners manual said it was adjustable but I stopped in fear of breaking it. How hard did you have to push it and did you use any special technique?
  5. Kirkuleez
    220
    24
    Oshkosh, Wisconsin
    Were you able to adjust it while it was closed?
  6. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    only while it was closed. and i had to make it an offer it couldnt refuse:)
  7. formula
    formula Member
    320
    32
    CA
    I think you can just push the top a little bit and it should slide forward.
    same thing on my civic
  8. R11
    R11 New Member
    101
    17
    Portland, OR
    Does it slide forward enough to rest your elbow on it while holding on to the steering wheel though? I sat in a C at the auto show in January but that one didn't have the armrest/console in it unfortuantely...
    ron
  9. Kirkuleez
    220
    24
    Oshkosh, Wisconsin
    I finally got it!
  10. Kirkuleez
    220
    24
    Oshkosh, Wisconsin
    Unfortunately you are still unable to hold the wheel while resting your arm on it, only your fingertips. That's one thing I miss about my fit, although the Prius c's armrest is nicer and you can store stuff in it.
  11. R11
    R11 New Member
    101
    17
    Portland, OR
    Thanks for the info. Kind of a downer... :(
    ron
