Center console sliding armrest problem
Discussion in 'Gen 3 Prius Main Forum' started by davidbw, Sep 19, 2009.
  1. davidbw
    davidbw Member
    110
    29
    In front of my computer
    I have been having a problem with the sliding armrest. The armrest normally locks closed. Releasing the lock allows you to slide the cover back, exposing the beverage holder. Releasing the lock a second time allows you to lift the cover up along a hinge along the back edge allowing access to the center compartment. I have found that sometimes the cover latch disconnects, so that the lock never engages and you can swing the cover up even when it is in the forward position.
    I think this happened when I once reached to the right when I was in the driver seat (the car was parked of course when I did this) to try to get something that fell off the passenger seat between the seat and the door. My body pushed the armrest cover to the right which spread the left and right walls of the center console container slightly apart. The little tray inside the compartment would drop slightly keeping the two walls apart. The two locking pegs then would not reengage if you open the armrest cover and then close it.
    The solution is to lift up the little tray, and then the armrest cover will open and close normally.
  2. Sphyrna
    Sphyrna Priusite
    202
    180
    Miami, Florida
    I could have sworn the prius I test drove opened straight up from the closed position OR slid back and then opened straight up. The one I actually bought only does the slide back then hinge up. Lately I thought I was just imagining it. Thanks for clearing that up!
  3. SilverPriusIII
    SilverPriusIII New Member
    39
    Bay Area, Ca
    I found that the sliding back created a major problem if there were 3 passengers at the back seat and the console would hit the middle person's knee.
  4. DrJon
    DrJon New Member
    140
    16
    Pinetop, AZ
    I think the whole design of that center console sliding cupholder thing is the cheapest thing on my car. I'm beginning to not like this one aspect of the car. Ha, after 2 months I finally have a complaint!
