Changing headlight
Discussion in 'Gen 2 Prius Main Forum' started by naturenut, Oct 27, 2009.
  1. naturenut
    naturenut New Member
    I had one of my headlights on my 2006 Prius begin to work intermitently. Decided it was that the bulb was about shot (and hoped it wasn't a wiring problem). Looked in the manual and tried to change the bulb with the instructions there--no luck. I took the car to a mechanic and he assured me he would have the bulb replaced in a half hour max. He couldn't figure out how to do it. I took it to a Toyota dealership and explained what was going on and he told me you had to remove the front bumper to replace the headlight? Having no choice, I had it replaced to the tune of $150 for the bulb and $47.50 labor. Has anyone else replaced a headlight? How did you do it? I hate to think of replacing another headlight down the road.
  2. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    I assume due to the amount you paid for the bulb, you have the HID headlights and not the halogen type. You need to state which type headlight you have or list the package for your Prius.
    If you have the halogen type, replacement is described here: http://priuschat.com/forums/knowled...38842-how-change-headlamp-headlight-bulb.html
    If you do a search on "headlight replacement" in this forum you will see many threads discussing the problems with the HID headlights for 2004-2009 cars.
  3. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    If you have HIDS (and it sounds like you do), a lot of people have had success with the HID bulb replacements they get on eBay for less than $50 for two bulbs.
    And there's a photo album and instructions on PriusChat for changing the HID bulbs -- though they're not as good as the thread posted above for halogens which has detailed instructions and videos (but note that a lot of that stuff in the halogens thread should be applicable to your HIDS too).
    Do a search on PriusChat for HID bulb replacement.
    EDIT:
    Check out this thread about HID bulb replacements for 2006-2009 Prius; note that the last post also has a YouTube instructions video:
    http://priuschat.com/forums/gen-ii-...7938-my-hid-bulb-replacement-my-06-prius.html
    And here's the photo album instructions for the 2004-2005 Prius HIDs:
    http://priuschat.com/forums/members/bruceha_2000-albums-2004-prius-hid-bulb-replacement.html
  4. naturenut
    Yes, it is a HID bulb. I found the instructions in the forum. Thanks.
