Changing Navigation System
Discussion in 'Gen 2 Prius Technical Discussion' started by frhunting, Jun 15, 2006.
  1. frhunting
    frhunting New Member
    Is there a way to change to map in the Prius navsystem from US to Uk or anywhere else for that matter?
    Thanks in advance
    FRH
  2. walt
    walt New Member
    195
    Bel Air, MD, USA -=- Blair, Merlin, Merka
    <div class='quotetop'>QUOTE(FRH @ Jun 15 2006, 07:47 PM) [snapback]271878[/snapback]</div>
    If you live in the US, you get the North America DVD - so we get to switch between US and Canada. If you will be taking the Prius elsewhere, you will have to order a DVD for that region from the dealer.
  3. frhunting
    <div class='quotetop'>QUOTE(walt @ Jun 15 2006, 03:49 PM) [snapback]271879[/snapback]</div>
    Thanks for the quick response.
    Is changing the DVd a shop job or can anyone do it?
  4. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Changing the actual DVD is easy. And I assume when you start the car it just loads up and works.
