Charging line with extension cord
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by kenp11, Aug 30, 2016.
Tags:
  1. kenp11
    kenp11 Junior Member
    74
    Orange
    2014 Prius Plug-in
    Ignore ..i found the answer on the blog for guage of extension
    #1 kenp11, Aug 30, 2016
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    The wire size of the extension cord needs to be large enough to handle the charging current or the cable may overheat.
    Also the added cable distance adds impedance and voltage drop.
  3. kenp11
    74
    Orange
    2014 Prius Plug-in
    Thanks. I think i saw 16 guage wire needed for extension
  4. jdcollins5
    5,131
    1,342
    Wilmington, NC
    16 gauge wire is only good for about 10A. What is the charging current?
  5. kenp11
    74
    Orange
    2014 Prius Plug-in
    I think it is 12amps dahboard says charging at 3.3kw
  6. jdcollins5
    5,131
    1,342
    Wilmington, NC
    That says the 16 wire is borderline undersized and is probably warm to the touch during charging. How long is the extension cord?
  7. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    I use a 25' extension cord rated for 15A at work to reach the plug. No issues with heat and charging seems fine.
