Charging problem?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mongo, Aug 26, 2004.
  1. mongo
    mongo Junior Member
    31
    The other night my wife got the dreaded Red Car with the exclamation point icon. Buzzers buzzing, lights flashing. The battery drained very quickly. We had it trailered to the dealer. Of course, the next morning, the evil icon was gone, but the battery was still in the purple bars.
    They uploaded new software and called it healed.
    I don't think it is. I can't get the battery to charge into the green bars now. No matter how I drive - and I know how to drive so it is in charging mode. Even regeneratively braking down a long hill, it will NOT charge to the green bars.
    Any suggestions?
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    with the scan tool that the dealer uses, they can tell what the car is doing. So if you can't get it to charge I'd take it back and have them hook it up and have a look at the HV battery and all the parameters that the tool will show them. State of charge, voltage, Hi and Low voltage and temps and all the data the tool can pull. A drive with it connected to get a real time data flow would be in order as well. Keep us informed.
  3. mongo
    mongo Junior Member
    31
    They did put the scan tool on it, but I don't know that they drove with it. The scan tool showed all was well with it just sitting there.
    I have a feeling that I'll be back there very soon.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I seriously doubt there's a problem. If the car is responding normally then just drive it. One day it'll go into green bars when it needs to and that will be that. There is no reason to try to get it into the green at all.
  5. Frank Hudon
    4,147
    have you put many miles on it since the dealer "updated the software"? My thinking is along the lines of we did the 40D and now when it comes back we'll be able to get the codes. If you've only gone a few miles and the battery was severly depleted it might take a couple of hundred miles to get it back to normal. I'd still be leary of the soft ware patch.
  6. mongo
    mongo Junior Member
    31
    I drove it around some around midnight when it got a little cooler. Using regenerative braking, I was able to get it to 8 gloriously green bars. So I'm happy.
    Don't get me wrong, I don't want to keep it at that state of charge, I just wanted to see it get there and I was having trouble doing that no matter how I drove. Now that it has, I'll go back to driving normally.
    Thanks for the help.
    - Tom
