Check Hybrid System - Code P0B3D: Hybrid/EV Battery Voltage Sense "A" Circuit Low
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by BackRoadsTraveler, Aug 15, 2023.
  1. BackRoadsTraveler
    BackRoadsTraveler New Member
    Charlotte
    Is this code the kiss of death (battery replacement) or could it possibly be a wiring issue... or something else?
    I've seen some mention of possible wiring harness issues but nothing definitively.
    2010 Prius 250K miles. Driving on gas only now - No EV. What should I check first.. visually or otherwise.
    Thanks.
  2. Brian1954
    Brian1954 Senior Member
    1,626
    627
    South Central PA, USA
    Start your diagnostics by using the Dr Prius app. You will need to buy a Bluetooth OBD2 device to use with the app. Visit the Dr Prius website for more information. You can use the app to look at the voltage readings of the 14 battery blocks in the HV battery. Block #1 corresponds with voltage sensor A.
    Edit: Below is a link to a thread in this forum where the OP just purchased a $14 obd2 device to use with the Dr Prius app and posted a screenshot of their readings.https://priuschat.com/index.php?threads/242877/
    #2 Brian1954, Aug 16, 2023
