Check Hybrid System: Dead 12V battery, low fuel
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Beanz, May 29, 2024.
  1. Beanz
    Beanz New Member
    Walla Walla
    I have a 2010 Prius. I left the interior light on for over a week and drained the 12V battery. Tried jumping the car and got a "Check Hybrid System" error. Through research I chose to replace the 12V battery and add gas to the tank. I also cleaned the hybrid fan and vacuumed loose debris from around the hybrid battery. Put it all back together yesterday evening to no avail. I still have the "Check Hybrid System" error.
    Is this something I can fix on my own? Or will it require a dealer to work on it?
    I'm attaching pictures of the errors, the fuel level, and the hybrid battery level.
    I used a Nexas OBD2 BT reader and got the info below:
    Car Scanner ELM OBD2
    Version: 1.106.0/401060/GP
    DTC report
    Connection profile: Toyota Prius Gen.3 2010-Date: 5/29/2024 8:26:05 AM
    VIN: JTDKN3DU2A0198266
    OBD-IIOBD-II
    DTCs: 1
    U0100 [0xC100] Data bus, engine control module (ECM) A - no communication
    Status: Confirmed
    ABS control unit #2
    No DTC found.
    SRS/Airbag #1 No DTC found.
    Hybrid engine systemHybrid engine system
    DTCs: 1
    Status: Confirmed
    Motor generator No DTC found.
    Gear selector switch No DTC found.
    Telematics No DTC found.
    Steering (EMPS/EHPS/PPS) No DTC found.
    Dashboard/Instrument cluster #1 No DTC found.
    Climate/HeaterClimate/Heater DTCs: 1
    U0100 [0xC100]
    Status: Confirmed
    Multimedia/Navigation No DTC found.
    BCM #1/Convenience systemsBCM #1/Convenience systems
    DTCs: 8
    B1206 [0x9206]
    Status: Confirmed
    B1273 [0x9273]
    No Communication Between Sun Roof Control ECU & Body ECU / 73
    Status: Confirmed
    B2321 [0xA321]
    Status: Confirmed
    B2322 [0xA322]
    Status: Confirmed
    B2323 [0xA323]
    Status: Confirmed
    B2324 [0xA324]
    Status: Confirmed
    B2325 [0xA325]
    Status: Confirmed
    Status: Confirmed
    PM1 gateway No DTC found.
    Electric window/Driver door No DTC found.
    Electric window/Passenger door No DTC found.
    Electric window/Rear right door No DTC found.
    Electric window/Rear left door No DTC found.
    Sunroof/Sliding roof No DTC found.
    Entry & start / Smart keyEntry & start / Smart key DTCs: 1
    U0155 [0xC155] Data bus, instrumentation control module - no communication
    Status: Confirmed
    Power source control No DTC found.
    Electric windows main switch/control No DTC found.
    upload_2024-5-29_12-55-35.png upload_2024-5-29_12-56-1.png [​IMG]
    50,830
    did you test the new 12v to make sure it is fully charged?
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,311
    5,675
    Texas Hill Country
    Two most common problems
    1. Hybrid battery disconnect not engaged
    2. Jump was momentarily reversed blowing fuses including the 125a hidden in the engine fuse box. You can visually see a blown 125a using a flashlight. * 125a fuse visible from top.jpeg
    #3 rjparker, May 30, 2024
    PTS likes this.
  4. Brian1954
    Brian1954 Senior Member
    1,594
    620
    South Central PA, USA
    Does the car go into Ready mode?
    Can you start the car?
    PTS likes this.
  5. Beanz
    Beanz New Member
    Walla Walla
    Thank you for the replies. I had to go out of town for a long weekend for a graduation and ended up having to rent a car. I plan to start working on this again this evening or tomorrow.
  6. Beanz
    Beanz New Member
    Walla Walla
    No, I did not. I made an assumption, probably incorrectly, that a new battery would be fully charged.
    I've not had time to work on this for several weeks. I left town for a graduation and then work has been very busy. I figured the battery was charged and working correctly because the electronic locks were once again working. But, over the weekend I tried to unlock the car using the remote and discovered that the 12V battery is once again discharged (or at least it is acting as if that's the case).
    I purchased the 12V battery at Batteries Plus. I'll take the battery back to them and ask them to check it for me.
  7. Beanz
    Beanz New Member
    Walla Walla
    The car did not go into Ready mode and I was unable to start the car. Instead the screen went directly into the "Check Hybrid System" error message along with the other error lights.[​IMG]
    I don't think I reversed the jump, but this sounds like a very easy thing to check. I'll report back what I find.
    The 12V battery is drained again so I need to get that sorted before I can try to start the car again.
    #7 Beanz, Jun 17, 2024
  8. Beanz
    Beanz New Member
    Walla Walla
    I'm embarrassed :( to post this but wanted to tell the rest of the story. Somehow when I opened the fuse box cover to jumpstart my car I unlatched this wire connector. :rolleyes: I have been unable to start my car since then. My assumption was that I couldn't jumpstart the car because the 12V battery was too low, but I've learned that shouldn't prevent a jumpstart. I looked in the engine compartment several times since then to check things in the fuse box and to disconnect the white cable going to the fuse box. Only last night did I notice that the connector wasn't latched. After putting the (newly tested and charged) 12V battery back in place and latching the connector my car started right up. (y)
    I am SO relieved. Thank you everyone for your help. :)
    Kromis and Brian1954 like this.
