CHECK HYBRID SYSTEM - Inverter coolant
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Flaninacupboard, May 24, 2011.
  1. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    I'm interested in some opinions. 1,500 miles ago my car had it's 30k service. Today, i got "CHECK...". At home this evening i checked the inverter coolant reservoir, it was empty. I've added 1L of de-ionised water (which got it to full, and i see turbulence in the fluid) until i can get the correct fluid, but as i say would like some opinions.
    Could the car naturally lose 1L of coolant in that period (assuming the dealer checked it and it was full)?
    Is anyone aware of inverter coolant pumps leaking?
    If the cap on the reservoir was left loose (i don't think it had been turned past the "click") could it evaporate 1L of fluid in 1,500 miles?
    All opinions/experience welcomed!
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    38
    Santa Fe, NM
    The fluid leaves behind pink crusty crystals when it evaporates. Do you have reason to believe that they performed any service to your car that would affect this system, such as an inverter coolant drain/refill or transaxle fluid change? One thing to look at would be the drain plug, in case someone opened that and then failed to torque it properly.
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I'm at 47k and my inverter fluid is still at the same level it was when new.
    I did have an issue a month or so ago with a 'check hybrid system' error but this wasn't connected to the inverter.
    Hope you get it sorted out. It does sound suspiciously close to your last service. Did you ask them to change the fluid? At least you're still under warranty.
  4. Flaninacupboard
    1,297
    213
    Midlands - UK
    It's going to the dealer tonight for a fluid change and diagnosis on where the fluid went.
    The service schedule says they should have inspected the inverter fluid, but it doesn't get replaced unitl (IIRC) 150k. Transaxle fluid is next service, 40k.
    Where is the drain plug for the inverter fluid?
  5. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Inspection is not done at the drain plug. Loss of coolant is not normal.
    They never actually do the transaxle fluid unless you force the issue. I would and then every 60k miles thereafter.
    JeffD
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    It is not possible, in a properly functioning system, to lose that much fluid. Mine is at 41K miles, 21 months old, and has never lost a drop that I can detect.
    My guess, they guy that changed to oil took out the wrong plug lost the coolant and didn't bother to replace it. If it had suddenly developed a bad leak I think you would see it running out.
    Drain plug for the inverter, if I remember correctly, is right under the transaxle, it is beneath the under engine cover but I think you could reach it without removing the cover if you bent the edge of the cover to one side a little. I checked the plug on mine for tightness without removing the cover. The inverter coolant leak TSB attached below does give you some idea where the drain plug is. I don't think that TSB addresses your problem because it would just be a drip now and then.
  7. Flaninacupboard
    1,297
    213
    Midlands - UK
    Thanks Tumbleweed, that's useful info.
    I did wonder if some fluid has been drained accidentally, but couldn't understand why it wouldn't throw an error until 1,500 miles later. i also wonder if long-term damage could have ocurred because of driving it without the coolant.
  8. tumbleweed
    4,067
    690
    Eastern Oregon
    That's good question seems like it would have shown up sooner, they might find some kind of leak.
    I doubt if there was any long term damage, the inverters have over temperature protection and would simply shut down to protect themselves. I would really keep a close eye on the level for a while if they don't find anything leaking, just in case.
  9. Flaninacupboard
    1,297
    213
    Midlands - UK
    It's definitely leaking, i had to add another litre of water tonight, and i could observe some fluid underneath the inverter.
    It's at the dealer now and i have an auris. it has a manual gearbox, and the engine runs when you're braking :(
    I'm guessing they won't have a pump in stock, so i wonder how long it will be.
  10. tumbleweed
    4,067
    690
    Eastern Oregon
    That's good news, at least you will know it's fixed. You are not the first with a bad inverter coolant pump to post on here, I don't think any of the others mentioned a leak however.
    http://priuschat.com/forums/gen-iii...91057-check-hybrid-system-new-water-pump.html
  11. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    Flan the dealership across the pond doesn't give you a hassle with your enginer kit and warranty void??
  12. Flaninacupboard
    1,297
    213
    Midlands - UK
  13. stefano5777
    stefano5777 Member
    380
    47
    Gotcha so where did you mount the plug?I assume not in bumper so under bumper?
  14. Flaninacupboard
    1,297
    213
    Midlands - UK
    Yep, just under the bumper.
