CHECK HYBRID SYSTEM
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by coolsam, Jun 2, 2012.
  1. coolsam
    coolsam New Member
    i un plug the battery and change the speedometer from US to CANADIEN. on a 2010 prius.now the car dont start .the hybrid orange symble lights up and CHECK HYBRID SYSTEM shows on my desh.is there any way to reset the hybrid system.tks
  2. Rebound
    Rebound Senior Member
    3,970
    2,624
    Portland, OR
    Try turning the car on and off three times. That should do it.
    tankyuong likes this.
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Could be a low 12v, especially as your car is new. I wonder if you do lots of short runs and/or left the interior lights on.
    If this message was a glitch then it'll go away. If it starts to become a problem you'll see it more often but only really start to worry if you get a orange warning light come on, and if it goes red then you have a big problem.
    See if it goes away and not worry. If it does it again then get your dealer to check it out under warranty.
  4. RRxing
    RRxing Senior Member
    2,528
    1,803
    NEPA
    Why did you have to unplug the battery (hybrid or 12V) to switch from MPH to KPH?
    If you unplugged the hybrid battery, maybe you didn't reset the safety plug properly.
  5. coolsam
    coolsam New Member
    i tryed as you say ,on and off 3 times but still same problem.every thing els works but i cant put to drive cauz its not ready
  6. Rebound
    3,970
    2,624
    Portland, OR
    I disconnected my battery to install some stereo equipment, and I had the same warning, and I had to turn the car off and on three times before I could start it.
    Most likely, either you didn't reconnect the battery well, or the 12V battery needs to be charged, or possibly replaced. If you had it disconnected for a few days, it might just need a charge. Read this thread for more info:
    My 2010 Prius wouldn't start up today, AGAIN! | PriusChat
  7. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Did you mess with the orange service plug on the HV traction battery? ImageUploadedByTapatalk1338789249.761403.jpg
    Posted from my iPhone via the Tapatalk app.
    dave77 likes this.
  8. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Moved thread to the proper forum.
  9. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Any news coolsam?
