Check hybrid system
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nicoj36, Feb 12, 2024.
  1. nicoj36
    nicoj36 Active Member
    516
    161
    Sup prius fam,
    Did egr cleaning on my other prius today and forgot to attach one of the hoses for throttle-body. Check hybrid system came up after starting. I connected the hose and it started but the check hybrid system is still there. Would it clear itself eventually once it realizes everything is good, or should it clear it with obd? Also what are other ways to clear check hybrid? 12v disconnect?
    thanks prius fam
  2. Mr. F
    Mr. F Active Member
    386
    251
    Washington
    Hard to tell without knowing the specific code that was triggered.
    Brian1954 likes this.
  3. Mendel Leisk
    40,233
    A coolant hose?
  4. nicoj36
    516
    161
    Not sure exactly but it's the one facing towards the front of the car, right in front of the throttle body
  5. Mendel Leisk
    40,233
    That might be fuel vapour return, going into intake manifold, just below throttle body. Leaving that off would make a significant vacuum loss.
    nicoj36 likes this.
