checking dash lights
Discussion in 'Gen 2 Prius Technical Discussion' started by J_w73, Oct 1, 2009.
  1. J_w73
    J_w73 Junior Member
    67
    I just got a used 2007 prius and am wondering if there is a way to test check the dash lights. I know like most cars the dash warning lights come on as you push the button.. I have noticed that not all of the lights come on.. should they? I can see a shadow of a big triangle and maybe some others.
  2. Politburo
    Politburo Active Member
    971
    208
    You can test the red triangle by putting it in drive and opening the door.
    I guess you don't have a manual? That would list all the lights. I don't think they all come on during startup.
  3. J_w73
    J_w73 Junior Member
    67
    Thanks for the info..
    I have the manual.. The red triangle I guess is the only one that I can't test.. well couldn't test.. some light up at start.. and others come on from steering wheel buttons.
    I will try your method to confirm the light works..
    thanks again.
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Ok, I am curious. Who has gotten the Big Red Triangle often enough to burn out the bulb? Raise your hands!
