Choosing the correct synthetic
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by momstoys, Nov 28, 2005.
  1. momstoys
    momstoys New Member
    35
    It is approaching the time for my 10,000 mile oil change. I want to switch to synthetic but don't know what to buy. There were far too many choices on the shelves! I will take the car to a local mechanic but the doesn't stock synthetic.
  2. aaf709
    3,862
    2022 Prius Prime
    My 10,000 is coming up and I plan to use Mobil 1 synthetic 5-30 (as I did at 5,000). That one seems to pop up a lot in posts.
  3. bigj3347
    bigj3347 New Member
    161
    Hacienda Heights, Ca
    I use mobil 1 5w-30 . . . .they sell 6, 1 quart packs at costco for $27
  4. GreenMachine
    GreenMachine New Member
    760
    Vermont, USA
    You might find this thread very helpful.
    http://priuschat.com/index.php?showtopic=12426&hl=synthetic
  5. ceric
    ceric New Member
    1,114
    Fremont, CA
    I do what bigj3347 suggested. I go to Costco and pick up whatever there is. Usually, they carry Mobil-1. The differences among all synthetic oil are not that large. Especially you really don't intend to race your Prius or anything like that, do you? :)
  6. davedog
    davedog Member
    403
    SF Bay Area, CA USA
    Mobil 1 synthetic 5-30 ... get the mobil 1 filter too!
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    A lot of it also depends on where you live too. In most climates the factory recommended 5W-30 should work just fine, and oils like Mobil 1 appear to be quite stable in use.
    Here in Winnipeg, it's prudent to run a 0W-30, which I started using after a 16,000km "break in." I'll probably run a 0W-30 year round, though for just this winter I'm trying Mobil 1 0W-20 as a "winter" oil.
    I'm going to perform Used Oil Analysis on the test with 0W-20 in mostly cold winter city driving to see what effect there is on wear metals. I would NOT recommend using a different viscosity unless you are also willing to closely follow up with a used oil analysis, especially a viscosity quite a bit different than what the maker recommends.
    An interesting and surprisingly good choice here in Canada is a HD motor oil made by Esso, called XD-3. It's available in 0W-30 and 0W-40, and is SL rated. Mobil 1 costs $8.25 a litre at Canadian Tire but I can get Esso XD-3 0W-30 for only $4.20 a litre.
    http://www.imperialoil.ca/Canada-English/F..._Xd-3_extra.pdf
    You'll notice Esso isn't afraid to go into detail about their product.
  8. silentak1
    silentak1 Since 2005
    893
    28
    LA
    Don't forget about getting a GOOD filter.
    K&N, Mobil 1, Bosch
    Do not get FRAM, or AC Delco. Purolator is OK if you can't find any of the above.
  9. jeromep
    jeromep Member
    827
    Eastern Washington State
    What matters is getting the correct weight of oil. Pretty much any synthetic, if you go that route will do you just fine. But unless you are living in exceedinly cold climates 5w-30 should do you just fne.
    As for filters; I have used Purolator, and more recently, Purolator PureOne filters for a long time. They are a quality product. Not just kind of better than the stuff from Fram, but up there with the premium filters, without the Premium price.
