Clazzi seat covers installation help!!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by needaprius, Feb 6, 2011.
  1. needaprius
    needaprius Junior Member
    50
    us
    Got clazzio seat covers for prius 2010 package 3. Installed the bottom part of the drivers side seat cover which is bit easy. Tried to install the top part of the driver's seat. Got couple of questions:
    1. The holes for head rest did not go easily for me. Had to pull, push and press to get them fit. Is that the way you guys had to do or was that a breeze as some one quoted. The reason why I ask is I would like to know if I am doing something wrong.
    2. The instruction document for "the back of the front seat" page on step :6 says fix the cover with velcro. May be I am not doing right, in my case the velco part and the mating end of the velcro( where velcro attaches) are not meeting. There is atleast 1/2" gap. Did you guys able to stick the velcro parts together? Please let me know.
    Thanks
  2. cossie1600
    cossie1600 Active Member
    899
    92
    CT
    You need to pull them HARD, your fingers should be sore after the install. It's tight because it is new leather and that is what will give you the stock new look
  3. needaprius
    50
    us
    So you are saying I should try pull the covers on both ends to make the velcro meet. Right?
  4. cossie1600
    899
    92
    CT
