Cleaning inside of windshield
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Russell, Jan 12, 2007.
  1. Russell
    Russell New Member
    Long Neck, DE.
    I have an '07 and the inside of the windshield is getting dull due to outgassing I assume.
    Has anyone found a simple way of cleaning it completely since it is so far from seating arrangements?
    My arms aren't long enough to do it completely without an extension or climbing over the steering wheel.
    Thanks
    Russ
  2. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    <div class='quotetop'>QUOTE(HiWheel @ Jan 12 2007, 06:23 PM) [snapback]374876[/snapback]</div>
    You can find some suggestions regarding this in the threads below. The suggestion of standing outside the car seems a good one. We need to do this with our car as well, and if I need to reach farther I think I'll take our swiffer apart and attached whatever cloth I'm using to it.
    http://priuschat.com/index.php?s=&show...st&p=363368
    http://priuschat.com/index.php?s=&show...st&p=110175
  3. klevitsky
    klevitsky Junior Member
    34
    A microfiber cloth, the kind you can buy at Walmart for washing your car in 5 or 10 packs, works great for removing that film. There may be versions where the microfiber cloth or mop is attached to a stick (for washing the outside of the car) that you could use on the inside to reach the bottom of the windshield, see the pic for an example.
    [attachmentid=6232]
  4. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    I use Glassmaster and Invisible Glass cleaner it really makes glass cleaning easy.
