Cleaning Plastic Over Dash
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mitchs, Jul 18, 2008.
  1. mitchs
    mitchs New Member
    toms river, nj
    What would be the best product to use to clean the large dark plastic area that I would best describe as above the dashboard. Is this material delicate. Thanks
  2. chrisspaulding
    chrisspaulding sexy, high tech, fun
    556
    24
    Kentucky
    Absolute best product is 303 Aerospace.
    This stuff works SO good on the dash plastic as well as all interior/exterior trim.
    Bonus, it's developed with anti dust properties. A swiffer and this, your dash will look day 1 brand new at all times!
    I have some. Love it.
  3. McDonald
    McDonald New Member
    264
    Boston, MA
    Hmm, this stuff looks good. And they'll even send you 3 samples of 3 products of theirs for $5 to cover S&H. Hoping I can find it in a store and not just online.
  4. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    I ordered the samples and they arrived quickly.
    It is good stuff but I have used plain water on a microfiber towel for 4 years with very good results.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
  6. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    I agree, 303 Aerospace Protectant is best, and you can use it on all your plastic, inside and out. The anti-static really helps.
  7. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    would that stuff get rid of all the dust and lint or whatever on the top of my dash?
    the top of the dashboard is some kind of weird granular texture which makes it difficult to get looking clean
  8. chrisspaulding
    556
    24
    Kentucky
    Like I said earlier, the combo of a swiffer and 303 will keep your dash practically lint free and definitely less likely to collect new dust/lint.
    303 also has UV protectant (forgot to mention this earlier). One of their tag lines is "SPF 40 for your stuff"
    Can black do that? NO!
    303 info:
    303 is THE LEADER in UV screening technology and 303 Protectant really is like "SPF 40 Sunscreen ... For Your Stuff." Regular use of 303 Aerospace Protectant can reduce UV caused slow-fade by up to 100%. No other protectant beautifies as intensely, protects as powerfully or lasts as long.
    The World's Most Manufacturer-Recommended product: Because of its enduring cosmetic properties, resistance to dust, soiling, and staining, water repellency and unparalleled protective abilities, manufacturers worldwide recommend 303 Aerospace Protectant for countless uses:
    Use on Rubber: Latex, Neoprene, EPDM Seals, weather-stripping, Wet/dry suits, rubber roofs, Vinyl, Hypalon, Urethane Vinyl awnings, clear vinyl, convertible tops, tonneaus, car bras, spa covers, pool covers, inflatable boats and so much more !
  9. McDonald
    McDonald New Member
    264
    Boston, MA
    You should wipe the dash clean before you use the 303 though, right? Because it's a protectant, not a cleaner.
  10. chrisspaulding
    556
    24
    Kentucky
    That's what the swiffer is for :)
  11. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    I too have used just plane ol' FREE water for (as of next month) four years.
    I fail to see the logic behind paying for a product which is essentially just more chemicals, and then spreading it around in a confined compartment where you spend many hours . . . when a slightly damp cloth is what Toyota recommends.
    Yes, the MSDS for this product shows it only being a slight health hazard . . . but that is still more than water . . and just how many of you actually use gloves when applying the stuff?
    I'll stick to using water only.
  12. chrisspaulding
    556
    24
    Kentucky
    That is a valid point about the chemicals
    But just water = dash fading
    I hope since I only use 303 once a few months that I'll be OK from any chemical harm. Can't be worse than that new car smell
