Clever electrostatic hover
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Dec 22, 2021.
  1. bwilson4web
    16,076
    Source: Engineers test an idea for a new hovering rover
    Because they lack an atmosphere, the moon and other airless bodies such as asteroids can build up an electric field through direct exposure to the sun and surrounding plasma. On the moon, this surface charge is strong enough to levitate dust more than 1 meter above the ground, much the way static electricity can cause a person's hair to stand on end.
    Engineers at NASA and elsewhere have recently proposed harnessing this natural surface charge to levitate a glider with wings made of Mylar, a material that naturally holds the same charge as surfaces on airless bodies. They reasoned that the similarly charged surfaces should repel each other, with a force that lofts the glider off the ground. But such a design would likely be limited to small asteroids, as larger planetary bodies would have a stronger, counteracting gravitational pull.
    51,326
  3. ETC(SS)
    6,992
    I always wondered how those things dissipated all of the static electricity that they generated, or was there one heckuva jolt when it landed.
    Regenerative landing?
    …or did they just dump it like “waste” heat?
