click underneath the drivers seat
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fussion101, Nov 13, 2009.
  1. Fussion101
    Fussion101 Junior Member
    81
    NYC
    Besides the constant rattling of the dash I'm getting a clicking right under the driver's seat.
    It happens when slowing to a stop at low speeds. It is just one click and can be heard and felt somewhere under my seat.
    It's not the relay click from the brake pedal.
    I thought it was my seat that was loose but it seems solid when I'm jostling around.
    Anyone with the same experience?
  2. garygid
    garygid Senior Member - Blizzard Pearl
    379
    23
    Orange County, CA
    No ratteling here, maybe I got a good one (from factory 5).
    I do not hear a click when braking from higher speeds,
    but such a sound might be hidden by the road and tire noise.
    Joke:
    And, hidden by the loud screeching of the brakes,
    the ABS noise, and the people screaming!
  3. Azimuth
    Azimuth Member
    136
    32
    Austin
    I have the exact same symptom.
    I hear a single click that sounds like the sound a wrench handle makes when it hits the frame on a car.
    I hear it once half way through acceleration, and then once half way through deceleration. it's reproducible especially when going up hill: I can hear it when pressing the accelerator and when not pressing accelerator but due to the uphill factor, the speed changes more rapidly, no brakes involved.
    I have a Monday appointment for the service department to look at this problem and a problem with the display buzzing intermittently on startup.
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I have this same problem. It has something to do with the part that moves the seat up and down. the higher i have my seat the more it does it, and if i lower my seat it will not do it.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I believe somebody posted having the same issue, and that there is a TSB which addresses the issue.
  6. Fussion101
    81
    NYC
    anyone have a pdf of this tsb? It's probably just one bolt somewhere that needs tightening.
  7. Azimuth
    Azimuth Member
    136
    32
    Austin
    The dealership was unable to replicate any of my issues. I got nowhere with them on this issue.
    I plan to test drive with the tech next time when I get time.
