Closing the hatch
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by aforkosh, Aug 6, 2005.
  1. aforkosh
    aforkosh Active Member
    412
    269
    Oakland, CA
    2023 Prius
    Having driven my Prius for over 1.5 years and 20,000 miles, I was surprised to discover something new (to me) and useful. Many, or most, of you may already realize this, but I figured I pass along this discovery to those still in the dark.
    As a preface, prior to the Prius, I owned a 1982 Tercel hatchback. On that car, the licencse plate lights were on each side of the rear plate and the housing for the right one provided a firm handle for closing the hatch. When I got the Prius, I discovered the inside handhold, but found that I usually did not generate sufficient force using it to firmly close the hatch. My technique evolved to thrusting the hatch down using the handhold and then firmly guiding the hatch down with my hand at the base of main window just above the spoiler. I have never really liked that, as I occaisionally would put a bit of pressure on the spoiler and could feel a little bit of flex there.
    I have now discovered a much better point for secondary pressure: the Toyota emblem between the licence plate and the slit window. I find that by pushing against the emblem, not really down, but in, the hatch closes firmly. In fact, unless I hold back a bit, I end up slamming it into the lock.
  2. baxsie
    baxsie Member
    141
    Spokane, WA
    LOL, it took me two days and a picture in the owners manual to even find the inside handle. But once I found it, (like you) I started using the emblem to finish the closure so it does not scratch the paint.
  3. fortheanimals
    fortheanimals Junior Member
    87
    portland, or
    i use the license plate area.. particularly when my prius has just had a cleaning and is spotless 8)
  4. Tideland Prius
    16,401
    Hmm, I don't know about you guys, but I've noticed that my hatch is easier to close and doesn't feel as heavy as before. Heck, when I close it now, it's a hard slam rather than a good closing thud before. Has anyone else experienced this? Is there something wrong with the gas struts?
  5. Old n Bold
    Old n Bold New Member
    79
    Bellingham, WA
    Yeah. I found a pretty bad way to close the hatch.
    I was coming around the passenger side. My wife had just unloaded the rear end and the hatch was up. I reached up with my hand on the side of the hatch and gave it a good slam down. I didn't look up or realize that there was still a lot of hatch between my hand and the bottom of the hatch. The pointy corner bottom right hit me in the head.
    My wife came around the other side and is was bleeding like hell all over the place. Popped me right in the front center of the scalp.
    Now I stand behind and look up when I slam it down.
    Bye the way, very little sympathy from the wife.
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    My hatch used to need a good hard slam or it wouldn't latch properly.
    When I had the car down in Rochester MN I stopped by a local Wal Mart and picked up a can of white lithium grease on sale. I gave the latch a liberal spray and opened/closed the hatch a few times.
    It's now MUCH easier to close. The latch must have been dry and stiff.
  7. baxsie
    baxsie Member
    141
    Spokane, WA
    The lift struts in my 2000 Sienna are now pretty weak. I talked to the dealer about replacements, but they were really expensive.
    Anyone have a good lift strut source?
  8. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    <div class='quotetop'>QUOTE(baxsie @ Aug 16 2005, 12:26 AM) [snapback]117062[/snapback]</div>
    My struts have gotten a bit to firm. Any ideas to make closing easier? Any twisting/screw adjustments like a normal house storm door? Should I just spray it with something? What kind of lube? Silicone? Grease? Kerosene?
  9. Godiva
    Godiva AmeriKan Citizen
    10,339
    I find the inside hand hold is usually sufficient to close it. However I did purchase a handle thing for my license plate frame. It attaches to the frame on the bottom and provides a little handle to finish the closure without using the spoiler, emblem or any other painted portion of the car.
    license plate handle
  10. kdk84
    kdk84 New Member
    113
    Michigan
    i usually pull it down with the built in handle and then finish it off with a hand on the rear spolier (no flex noticed)... seems to work fine.
  11. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    what?? no one uses the rear spoiler as a giant handle to close the hatch?
    is it because people are nice to the rear spoiler? and
    dont want to damage it?
    or is it because of the shortage of touring models??
  12. aforkosh
    412
    269
    Oakland, CA
    2023 Prius
    As the starter of this thread, let me re-iterate the main points that I made:
    1) I felt some squishiness when using the spoiler, so I experimented with other locations. I didn't want to accidentally snap it off.
    2) The Toyota emblem works as almost a magical lever. A minimal amount of pressure against it shuts the hatch down with surprising force.
  13. Tom6850
    Tom6850 Retired
    898
    Leesburg, FL
    <div class='quotetop'>QUOTE(Godiva @ Jun 22 2007, 12:38 AM) [snapback]466201[/snapback]</div>
    I have a license plate handle but I mounted mine on the top with the license bolts. Won't the bolts on the bottom of the plate scratch the paint?
  14. Godiva
    10,339
    <div class='quotetop'>QUOTE(Tom 6850 @ Jun 22 2007, 02:44 PM) [snapback]466501[/snapback]</div>
    I only have holes in the top of the license plate frame. So I used the holes in the bottom of the license plate to mount the handle to the plate. That holds the handle and the frame goes over the lot. I used shallow bolts and bolted from back to front. I then put pad protectors on the heads of the bolts to protect the paint. I don't think I really needed to do that. Whatever...the license is going to cover those spots.
  15. h2photo
    h2photo Member
    432
    Chandler, AZ
    I use the license plate as my hand placement after I pull down from the inside. When at Toyota, they told us to use the spoiler or else it would throw the hatch out of alignment. But I don't like fingerprints on my paint!!
  16. rigormortis
    1,340
    26
    san jose, ca
    i just mentioned the spoiler to rub it in that i have a touring model, heh
  17. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(baxsie @ Aug 6 2005, 12:10 AM) [snapback]113935[/snapback]</div>
    There's an inside handle? I've grabbed the spoiler but I don't like the give. The emblem works well.
  18. ohershey
    ohershey New Member
    632
    I find that with just the right snap of the arm down and then away from the car, I can close the rear hatch using just the inside handle - no need to worry about emblems, spoilers or incriminating fingerprints.
    You must practice your ninja hatch skills. I'll try to get a little video clip to post. :D
  19. 8AA
    8AA Active Member
    550
    62
    Maryland
    I also use the inside handle to get the hatch started, then switch to the Toyota emblem.
  20. priusincc
    priusincc Member
    332
    16
    NV
    <div class='quotetop'>QUOTE(8AA @ Jun 23 2007, 04:03 AM) [snapback]466807[/snapback]</div>
    Ditto :p
