Hi Everyone, I have a used EV switch from Coastal Electronics. I installed the Hymotion upgrade and they removed it during the installation. Instructions included along with wire tap. This would make a perfect Christmas gift. $25 including UPS shipping to the continental U.S this is normally $45 and you would be taking your chances to receive by Christmas,. Will ship to outside US for actual shipping costs. The electric mode kit is designed for ease of installation and includes the necessary pin and connectors to complete the installation. Color photos and step by step instructions explain how to insert the missing pin and clip on two wires using simple wire taps. No wires are cut and very little disassembly is necessary to activate this feature. Once installed, the kit will create two possible uses for the "Cancel" function of your cruise control stalk. If you pull the cruise control stalk toward you (as when using the "Cancel" feature) and hold it for more than two seconds, the electric only mode will be signaled and the factory software will shut down the engine (or prevent it from starting if you are just turning on the car). This method will also turn off the electric mode when desired. The normal operation of the "Cancel" feature when using the cruise control is unaffected by the addition of the circuit and will continue to function as usual. I will accept PayPal or credit card for payment.
