Cold Weather and CVT
Discussion in 'Gen 2 Prius Main Forum' started by Dcnight, Jan 18, 2005.
  1. Dcnight
    Dcnight New Member
    Hi all - first post for me but I have been reading posts here for over a year.
    I just picked up my Prius last Last Thursday just in time for an extreme cold snap. I have noticed that the CVT does not like the cold weather very much - when taking off in the morning, the car seems like it 'surges' even though the MPH does not drop off. I would almost say the the transmission is slipping if that is possible with a CVT. This morning it was 4 degrees out and I actually had to stop and pull off the road and stop as the engine was racing and I was hardly moving. Once it is warmed up - I have no problem.
    Has anyone else observed this?
    Thanks in advance!
  2. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Since you have been here for a year, remember that the 'CVT' does not shift like a normal car would. The 'transmission' is a power split device, transferring power between both the wheels, and the MG1 (motor generator). The ICE will operate at a constant speed for the power requested, and as the car moves faster and faster, more power will shift from MG1 to the wheels. What MG1 generates from the 'excess' energy will either be directed to MG2, or the battery.
    When the car is cold, HV will run ICE to warm it and the Catalytic up, even with no power demand. Some energy from this may be stored in the battery, but it is speculated the Hv may be limiting the load on ICE during warmup.
    Good links:
    http://home.earthlink.net/~graham1/MyToyot...PriusFrames.htm
    and John's website, which I can't find right now.
  3. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I've noticed too that it acts like a reg. automatic is slipping, but I've never had to pull off the road and stop cause the eICE was racing so much and this am it was 5 F
  4. DanMan32
    3,799
    27
    Tampa Bay, FL
  5. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I've noticed that it sounds like the engines running higher RPMs than what would otherwise seem normal. No worries. The thing with the Prius is that you can read all you want about it but it's when you actually get behind the wheel for an extended period that you realize all your previous frames of reference no longer apply.
    The good news is that if you can learn to get good mileage in the winter, you're going to kick some major MPG butt in the summer. The bad news is that driving in the winter really stinks.
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    We too had a cold snap and another factor is the defroster. For the first time I had the ICE coming back on at a stop light. The ICE was running more and at higher RPMs. I also saw more green battery than I have had in a long time. I think the care was doing it's job, keeping the engine at optimal temp for effency, keeping me warm though the thermostat was set on 68 most of the time, and keeping the windows defrosted. I have since learned to turn the defroster off when I don't really need it, the ICE runs a bit less and maybe a bit slower.
  7. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    There simply is no way to properly prepare yourself for the difference in sound & feel that the CVT provides, especially in the dead of winter.
    Trust me, it's totally normal. This is my 5th winter in Minnesota with Prius. The CVT works just fine, even at -18F degrees. The behavior will not resemble an automatic in any respect, especially when emissions are purged during the warmup portion of your drive (the engine will momentarily surge, even though the MPH doesn't change).
    In a way, it is rather amusing... since it gives you the impression the vehicle is struggling. But really, it isn't. You've just been trained to expect an engine to respond in a very specific way. Prius doesn't. Still to this day, I get a kick out of accelerating rapidly onto a highway. The brain still sometimes expects to feel the soft thump of a gear changing. But instead, you get absolutely nothing... just a smooooooth acceleration.
  8. richard schumacher
    7,664
    1,042
    United States
    And that improved things.. how? Did the engine stop racing when you stopped moving?
  9. john1701a
    12,793
    5,275
    57
    Acceleration during hill climbing gives the impression of a surge too.
    Rather than the engine slowly increasing RPM, the motor does that instead. Then RPM will plateau and the engine will quickly change to the next higher efficient RPM for those particular conditions.
    So if you're paying attention to sound, your brain will automatically try to counter that by making your foot compensate for the change in sound. The result is you fighting the CVT, rather than just letting it respond to road conditions the way it was designed to.
    In other words: JUST DRIVE IT
  10. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    We've already been down to -40 and I haven't noticed behavior like THAT. It's true the motor does seem to rev a bit faster, perhaps to assist in warmup.
  11. TonyPSchaefer
    14,816
    2,499
    66
    Yeah, whatever. As though you know anything about driving a Prius in cold weather. :)
    If John says it's normal, then by George, it's normal.
  12. john1701a
    12,793
    5,275
    57
    <hehehe> Winter isn't all that bad here.
    Though today's experience was a little odd. It has been around 0F degrees all of last week. That pushed my MPG dangerously close to the 40 mark. (Dipping into the 30's is not something I'd like to ever have to endure!) Well wouldn't you know it, the "warm" weather finally kicked in this evening. So when I filled up the tank, I was scared that reverse bladder-effect would cause the more gas to fit in the tank than last time... artificially deflated the MPG calculated. Phew! It was close. The value calculated to 40.1 MPG.
    Anywho, it sure was nice driving in a temperature 50 degrees warmer than it was just a few days ago. Boy, does that ever change the behavior of the hybrid system. I can't wait until it warms up another 50 degrees... in June.
  13. Dcnight
    Dcnight New Member
    Yes, john pegged exactly what happened when I started out - kind of (really) freaked me out as I listen pretty closely to what is going on in my cars and my mind said 'thats not right'. When I was accelerating onto the Interstate, I may have overreacted to the car 'doing what it does' based upon my earlier assumption that something was not right. I am going to chalk this one up to 'no valid frame of reference' and keep an eye on it. Thanks to all who answered.
    Best Regards to all!
  14. DanMan32
    3,799
    27
    Tampa Bay, FL
    Also, at a stop, if engine resists turning off, and you feel it should be adequately warm, try turning off the AC and see if the engine shuts down then. If it does, you now know why the engine is running even at a stop.
    Also, the ICE idle is a bit higher than a conventional car.
  15. KTPhil
    KTPhil Active Member
    1,379
    Hmmm, maybe if the Prius were loaded with gauges, this confusion wouldn't have happened? ;-)
  16. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Just to state "that's normal" one more time, the sound of the ICE has no relationship what-so-ever to the speed you're traveling. You will notice tendencies like ICE reving with acceleration, but it will rev more than you expect when idling too when the ICE is cold. Other times it will shut off completely.
    This is normal as can be.
  17. mss
    mss New Member
    106
    Connecticut
    What I have been noticing that bothers me is as follows, I don't know if it has less to do with the temperature, though I have only noticed it in the past week and it has been very cold. I have experienced this even when the engine is sufficiently warmed up.
    I get to a cruising speed: A steady speed between 40MPH to 65MPH. Using my foot on the accelerator (Not cruise), I keep a steady pressure. The terrain is flat. I will feel what has been described above. The ICE RPM is really not changing, but I feel a "surge", then a retreat. A cyclical behavior where it surges almost once a second. I do not feel a steady flow of power to the drive train. One might say it feels like a slippage of an automatic transmission, but it is different. It feels like CVT slippage.
    The MFD usually is showing power coming out of the ICE, and alternating display of power coming out of the motor to the wheels, or to generating electricity for the battery.
    To be clear, this is a feeling of power to the drive train, nothing to do with engine sound.
    - When I accelerate, it is as smooth as can be.
    - If I decelerate and am just in regenerative state, it is again smooth.
    - If I have to apply more power to maintain speed, when climbing a hill, it is also smooth.
    It is just when cruising on relatively flat terrain, mostly going highway speed where constant power to the wheels from the ICE is necessary, that i feel this surge situation.
    Help? Am I going crazy, or is this Normal. I don't remember feeling this behavior a two weeks ago.
  18. paprius4030
    2,077
    296
    York,Pa.
    mss, I've never experienced that type of sensation. Do you really have to pay close attention to feel it or not? If it's really noticable I'd take it to the dealer and let them figure it out. Hey can you feel it with the cruise control on? I wonder if that would eliminate the throttle sensor as the culprit????
  19. CHART
    CHART Member
    184
    Mount Airy Maryland, USA
    I've had my Prius since Dec 03 and I haven't ever felt "surging" like you (and others) have described. The temp here in DC has been teens to twenty's. You might want to have it checked.
    (P.S. 1st somewhat significant snow of the season today and the Prius handled it like a champ!! Of course, everyone else forgot how to drive!!!!!)
  20. DanMan32
    3,799
    27
    Tampa Bay, FL
    Definitely normal. Seems to be how it keeps the charge constant.
