compressed springs on prius
Discussion in 'Prius PHEV Plug-In Modifications' started by ohwhatafeelin, Mar 15, 2010.
  1. ohwhatafeelin
    ohwhatafeelin New Member
    melbourne
    has anyone compressed the stock springs on their prius??? any advice or feedback?
  2. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    I weigh 360 pounds. I feel sure I have compressed my poor Prius's springs, especially since the back looks like this
  3. a_gray_prius
    2,927
    783
    IL
    How did this thread make it into the PHEV forum? It's about springs?
    It's my opinion that you should replace both the shock and spring at the same time, but many members report good experiences with replacing just the spring. I don't have any personal experience regarding compressed springs, but it's my suspicion that a new set will give you somewhat better performance.
  4. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    145
    Fort Worth, TX
    Most likely because the weight of the PHEV kits may make the car sit funny and require spring upgrades. I noticed when putting my Enginer kit into my Gen-1, that it cause the rear to sink about 1 inch from normal. But it really wasn't all that visible if you didn't know what it looked like immediately before. And since I am re-designing my Enginer kit to get rid of the giant heavy steel box, it should make the load even lighter.
  5. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    I have found no spring upgrades for the Gen3 prius yet. The only solution I have found is to have customer springs made for the prius and that would be about $500 for 2 rear springs. I am desperately looking as I have about 330lbs of batteries and such in my Prius. The load is almost max so I cannot carry anyone or thing in my prius.
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    banshee,
    Have you tried contacting Luscious Garage, Pat's Garage, or 3Prong Power in the San Francisco area?
    They may have some ideas since they all do PHEV installs.
  7. boxer93
    boxer93 Psyched for PHEV
    155
    22
    Southern NH
    I have luscious springs in my 08 prius w/hymotion. I felt it was well worth it.
    Chris
  8. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    I will give them a call and see. I don't think the gen2 springs will fit the gen3.
    Thanks,
    Chan
  9. scottsim
    scottsim New Member
    78
    I seemed to have suffered a loss in handling with the bigger springs used in the 3Prongpower 10KWh conversion (300+lbs)...not sure what they used, but will be asking if they can tweak it a bit.
