Computer vs Actual MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by ddtaylor99, Aug 10, 2009.
  1. ddtaylor99
    ddtaylor99 dd taylor
    25
    cincinnati, oh
    Does anybody check the computer calculation for MPG to see how accurate it is? I checked mine and the computer appears to be overstating the MPG by about 7 Miles.
    (You know how to check MPG manually right? Fill tank - Set Trip Odometer to 0 - Drive around - Fill tank back up and divide your Odometer miles by the amount you added to the tank.)
  2. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    There are a number of threads addressing this issue. The two longest-running and best able to address your concern are the following:
    1. 2010 calculated vs. computer MPG - Please post your results (This thread is actually a "Sticky" that shows up at the very top of the forum.)
    2. 2010 Toyota Prius FCD Inaccuracy
    Other threads recently started on this topic include:
    1. Discrepancy between electronic mpg number and "actual" mpg number???
    2. MPG guage accuracy
    3. gas mileage
    These are the threads related to the 2010 (GenIII) Prius. There are several other threads on the topic as relates to the GenII Prius, but there are different issues involved.
    Please do a search to find out even more about this issue.
    2 people like this.
  3. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    The more EV mode driving and higher mpg numbers seem to be further off.
    I've got a little over 2600 miles and my lifetime computer avg is around 47.5 and my calculated is about 46.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Overstating by 7 miles over what distance, or did you perhaps mean that to be 7 miles in a gallon?
    Tom
  5. OZ132
    OZ132 Member
    170
    Northern Indiana
    Our indicated ios consistantly 3 to 4 MPG better than actual. It's misleading. Should be fixed. I've had to stop telling people I get 50 MPG.
  6. buzzard767
    buzzard767 New Member
    48
    Naples, FL & Wausau, WI
    Why don't the moderators merge all similar threads and leave thirty day or longer redirects?
