computer warning message
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by [email protected], May 28, 2009.
  1. ahernj@sbcglobal.net
    [email protected] New Member
    Jackson California
    caution
    press park to engage park
    battery will not charge if transaxle is in neutral
    This comes on the screen, while driving, if the driver door is ajar.
    Local Toyota says normal, just telling me my door is ajar.
    I would rather not say what I think.
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Yes, a Prius will reliably produce that scary warning message while in Drive, with the driver door ajar. As a test - safety first! - while in your driveway, seatbelt on, put it in Drive, then open the driver door.
    You will get the scary message. I've done that party trick to freak out passengers
  3. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Certainly not one of the better-thought-out warning messages.
    But yeah, it pops up when the door is open. Go figure.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    It's normal. I think that warning message was written by Microsoft.
    Tom
  5. ahernj@sbcglobal.net
    Jackson California
    Thanks, I really like my car, but that message has to be, well, STUPID! Jim Ahern
  6. qbee42
    18,058
    3,076
    Northern Michigan
    No argument about that.
    Tom
  7. ceric
    ceric New Member
    1,114
    Fremont, CA
    You should have seen the early BMW-7 (around 2004-5) that was running Window-CE.
    The screen actually displayed
    "the system is rebooting, please wait..."
    while the vehicle was cruising on highways.
    Scary? You bet.
  8. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
  9. kdinsmoor
    kdinsmoor Junior Member
    Venice, CA
    I currently get the same warning message. I get it when my door is closed though. I was rear ended recently at a low speed. I don't see much damage to the back of my car, but could it be a sensor from the trunk? If not, what else causes this message to come on?
  10. 2009Prius
    2,705
    511
    63
    I would check the 12V battery in the trunk.
  11. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Also check the tightness of the connections, including the bolt to the chassis ground.
