I am having problems with condensation in the display for my speed and mpg. I have also been having some issues with my radio shutting off or ejecting a CD when I press a preset button and sometimes randomly changing stations. It also sometimes displays weird things. I am wondering if these two issues are somehow related and that there may be some moisture inside the dash causing the issues. Has anyone here experienced the same thing or have any idea what could be wrong/how to fix it? Thanks for the help!
Had the same problem last week .Believe it came from condensation due to big change in weather from 80 degrees down to 30-40 deg. range here in Florida overnight. I also turned on the fan but forget to hit the front defrost switch.Fogged up all the windows.So I ran a laser lens cleaner through the CD player(overdue) and so far so good. This happened to me before during the summer when it was very humid out. Ran the laser lens cleaner and the problem stopped. I use my CD player 90% of the time. Hope this helps.
