Consequences of NOT replacing/repairing hybrid battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JLem, Aug 21, 2018.
  1. JLem
    JLem Junior Member
    Attleboro, MA
    I’ll start off by saying that I don’t know much about the technical ins and outs of car engines/hybrid systems. But, our 2006 Prius with 180k miles just threw all the warning lights, so we brought it in to the dealer to get checked. Short story is that it is a bad hybrid battery and it would cost $2,700 to replace. They actually said it is one module (?) that isn’t fully charging.
    My questions:
    1) can we continue to drive it without fixing anything? What are the risks?
    2) Any advice on whether sinking $2,700 into this is a good idea?
    Thanks for any help/advice.
  2. dolj
    dolj Senior Member
    8,111
    4,127
    Wellington, New Zealand
    No, not for very long. If you are handy and don't mind doing a crash course in battery construction and repair, you could fix it yourself reasonably cheaply. Don't buy someone else's second-hand problems (aka refurbished/rebuilt), they are just not reliable.
    Only really you can answer than, but it would depend upon (among other things) how good a condition overall your car was and how long you intend to keep it.
    Secondly, $2700 is a bit pricey in today's environment. Shop around. Yous should be able to get it done at the dealer for around $2200 OTD.
  3. JLem
    JLem Junior Member
    Attleboro, MA
    So, what would happen if the car was driven with a bad hybrid battery? Does it not just become a gas-only car? Or is the hybrid system so integrated into the car that it would just cease to run?
  4. dolj
    dolj Senior Member
    8,111
    4,127
    Nope.
    Yup.
    Skibob, ITBland and Raytheeagle like this.
  5. khp
    khp Member
    76
    45
    SW Washington
    I drove mine one time about 80 miles to a wrecking yard to buy a used HV battery with the triangle of death on ( clearing it once and a while) and barely made it 20 miles from the wrecking yard. The car wouldn't go any faster than 35 mph or so down the Interstate toward's the end. I was driving with the flashers on and pulled into where I worked and had some tools. Swapped the battery right there and then. It was fine after that but I won't do that again.
  6. JLem
    JLem Junior Member
    Attleboro, MA
    Thanks everyone. I've decided to replace the battery...but with a used/refurbished one through Green Bean Battery.
  7. Patrick Wong
    18,200
    6,490
    In general, a "refurbished" battery is not a great idea. It is not actually refurbished. Rather it is composed of a bunch of used battery modules.
    While the refurbished battery comes with a warranty, expect to have one or more failures during the warranty period. If you would be inconvenienced by experiencing occasional vehicle downtime, this would not be a good choice.
  8. #1 Toyota salesman
    110
    71
    GSP, SC
    Good luck...we'll be looking forward to your "help, my third refurb battery is throwing codes again" posts
    $1800 will get you a NEW Toyota pack, tax included, a few hundred more of you want them to install it
  9. thehybridguy
    thehybridguy New Member
    Dallas
    Your car will go into a limp/safety mode. This is designed to keep your car from damaging any else.
    Once the lights come on you may get maybe 60 to 110 miles of driving before the car will no longer drive.
    The enegine gets started from the hybrid battery. It does not have a starter. So you cannot run it like a gas only.
  10. JLem
    JLem Junior Member
    Attleboro, MA
    Just wanted to return to this thread to update. We replaced the battery with a refurbished one through Green Bean. That was about a year ago, and we've had zero problems since. The total cost was $1,550, which included the install and a full 5-yr warranty. Scheduling was easy and quick (our appointment was 4 days after making the request). They use mobile installers, so they showed up to our house, and swapped out the batteries right there in the driveway. I forget how long it took, but I don't recall it taking very long.
    all in all, our experience was excellent...and we saved a few hundred dollars. Of course, YMMV
    WHCSC, davecook89t and bisco like this.
  11. bisco
    50,804
    please keep us updated, a lot of green bean talk here lately.
    all the best!(y)
  12. Charlie JO
    Charlie JO New Member
    St. Louis
    Still good?
  13. Will N
    Will N Junior Member
    Southern California
    2014 Prius v wagon
    I don't think "Bad Hybrid Battery" means what we might think. My 2015 Prius V just failed it's California Smog check, with a P0A80 "Hybrid/EV battery needs replacing." Dealership would charge top retail price for a complete battery. So I found the highest rated local Hybrid Battery Repair. The drive there was 30 miles.
    What led me to this was I haven't driven the car much in the past couple of years. The 12v battery went bad. When I replaced it a bunch of sensors went off. Two mechanics with Readers told me to just drive it until the warnings reset. The smog check guy reported the P0A80 warning. The Scanners of the other two guys couldn't pick that up. For some of the first 30 miles after I replaced the battery, the average MPG dropped from 39 to 32 mpg (I have a roof rack which lowers it some. I think 42 is normal.) So I thought I had a problem,. but the car drove completely normally.
    On the 30 mile drive to the battery repair, driving normally, I averaged 42 mpg. That seems like there's no problem. The battery repair guy's sensor got the P0A80 warning and also one saying bank 11 of the 14 has a problem. So likely one sub-unit of that bank. He's going to charge me $600. (I'm sure I'm over paying a bit. But confidence it will be done correctly is worth at least 33%.)
    The biggest issues in all of this are:
    1. 2015 Prius V's aren't "Partially Zero Emission Vehicles" even though that's what the ARB Smog Check form says they are. So the 150,k 10 year California warranty doesn't apply. No one can tell me why.
    2. What does any of this actually mean? If my car is getting the same mileage, what's the big deal? For clean air, if it's getting the same mileage then it's burning the same amount of gas per mile. There's no reason it shouldn't pass. (The smog check for this car does not include taking any readings from the exhaust pipe.)
