Contradiction in 2010 Maintaince Book
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by paprius4030, Apr 21, 2010.
  1. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    So I'm going thru the papers, manuals ect. that came with my 2010 Pkg.2 Prius. I was reading the maintaince schedule and it says to change the ICE and Inverter coolant at 100k mi. But there is a little number 3 next to it, so I read the footnote (after getting a magnifying glass LOL ) and the first sentence says Initial change at 100k mi, thereafter every 50k mi. But then right under it the next sentence says, Initial coolant change 150k mi then every 50k mi thereafter??? So which is it 100k or 150k. And if your using the same coolant why should it be replaced every 50k mi. You would think that it should be good for another 100 or 150kmi.
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    100k mi is for engine coolant, 150k mi for inverter coolant.
  3. paprius4030
    2,077
    296
    York,Pa.
    Guess I have to re-read it better. I wonder why the difference?
  4. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    The water pump no longer working at its best therefore your coolant change is much sooner. However, that is if your water pump last that longer after 100k miles.
  5. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    (This is a wild guess) Toyota has paranoid worries about getting contaminants in the inverter, so they risk running 150k to keep it sealed. Once it is ever opened, they advise the 50k they would like to have specified, if if they weren't so worried.
