Coolant Temperture?
Discussion in 'Gen 3 Prius Main Forum' started by topkick, Jul 14, 2009.
  1. topkick
    topkick Member
    166
    Oklahoma City
    If anyone that has a Scanguage II would please tell me what their coolant temp. is running on a 2010?
    On my 2007 the Scanguage at highest was 181-2 degrees, now with my 2010 the Scanguage shows 191-3 degrees, does this engine run about 10 degrees hoter than the 2004-09's?
    I would appreciate any input, thanks.
  2. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    If that's all you saw, you likely had a broken thermostat (one that constantly remained open). 191-3 was the normal high you should have seen.
    191-5 is the norm for the 2010 model.
  3. topkick
    topkick Member
    166
    Oklahoma City
    Thanks that is what I wanted to know. It is possible the 2007 was wrong because that is the highest it ever got and that was a few months after I bought the 2007 and bought a Scanguage II.
    Happy to know the 2010 is running in the right range.
  4. aapoppa
    aapoppa formerly known as "Popoff"
    142
    NC Mountains
    Rarely exceeded 185 degrees in my '05.
    I'm now regularly seeing between 190 - 198 degrees in my new one.
